20 Most Recent
Dacor ECS127 Epicure Stainless Steel Electric Single Oven Questions & Answers
My Dacor wont heat, broil or convection after self cleaning
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem.
The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...).
I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site...
All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate.
6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out.
It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works!
This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
Ge jbs03004 oven
I purchase parts from an appliance parts supply. You could also purchase elements let's say from a Home Depot. You can buy used parts from area used appliance stores. Nowadays you can purchase almost anything on-line.
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oven light flickers on and off rapidly
I have seen several problems with the touch pad (membrane switch assembly) causing weird problems with the lights. also something to check is the door hinges. I have seeen several cases where the door hinges wear out and the door does not close completely and doesnt quite push the door switch in. The easiest way to check this possibility is to push in on the door while the light is acting up and see if it quits. If it doesn't, the problem most likely lies in the mebrane switch (touch pad). Good Luck!
The oven light flashes on
Hi chez_ulrich,
This problem is a common failure symptom. This is a bad touchpad, please replace it with new one. You can obtain the part at apdepot.com.
Hope it helps.
Thank you for using FixYa.
The light in the oven keeps going on and off, how
Call a repair man. He will swap the control panel, it will cost you $450 and it will still be broken. He will come back and change the circuit board that has the clicking relay. It will cost you $450 and will still be broken.
