that is not a problem. I copied the instructions straight from the manual which you can
also review by clicking here.
Using the clock and timer.
To Set the Clock
The clock must be set to the correct time
of day for the automatic oven timing
functions to work properly. The time of
day cannot be changed during a timed
baking or self-cleaning cycle.
Press the CLOCK pad.
Press the HOUR and MIN + or
– pads to set the time of day.
Press the START pad.
Make sure the clock is set to the
correct time of day.
To Set the Timer
Press the KITCHEN TIMER
ON/OFF pad.
– pads until the amount of time
you want shows in the display.
The maximum time you can enter
in minutes is 59. Cooking times
more than 59 minutes should be
changed to hours and minutes.
For example, enter 90 minutes as
1 hour, 30 minutes.
If you make a mistake, press
KITCHEN TIMER ON/OFF and
begin again.
After pressing the START pad, SET disappears;
this tells you the time is counting down, although
the display does not change until one minute
has passed. Seconds will not be shown in the
display until the last minute is counting down.
When the timer reaches :00, the
control will beep 3 times followed
by one beep every 6 seconds until
the KITCHEN TIMER ON/OFF pad
is pressed.
The 6-second tone can be canceled by following
the steps in the Special features of your oven
control section under Tones at the End of a
Timed Cycle.
The timer is a minute timer only.
The timer does not control oven
operations. The maximum setting on
the timer is 9 hours and 59 minutes.
To Reset the Timer
If the display is still showing the time
remaining, you may change it by pressing
the KITCHEN TIMER ON/OFF pad, then
press the HOUR and MIN + or – pads
until the time you want appears in the
display.
If the remaining time is not in the display
(clock, delay start or cooking time are in
the display), recall the remaining time by
pressing the KITCHEN TIMER ON/OFF pad
and then pressing the HOUR and MIN +
or – pads to enter the new time you
want.
To Cancel the Timer
Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
