Be sure the timer (right most knob) is set back to MAN (manual) after cleaning in order for the oven to work.
SOURCE: Replacement knob
imsert your model number here, you can download a complete parts manual
http://www.frigidaire.com/support/manuals.asp
Hey friend, thank you for your post!
I see your oven lock light is flashing and the oven is not working on your Frigidaire range. Are you able to provide model number, with that information I can research any additional information for your range. You can locate the serial tag (which lists your model number) behind the bottom drawer of your range. Thank you for the post and I look forward to assisting you. -Matt
Hi michell51238 - From what you are describing it sounds like the range may possibly have a faulty light switch or wiring failure that only a professional can repair. I personally recommend consulting a certified technician for a proper diagnosis and to move forward accurately.
I need a relpacement
Hi, How do I operate the oven in my Frigidaire Compact 30. It was working before and I think I pushed one of the buttons on the timer by mistake while cleaning the unit, and now the oven does not work. How do I reset it or make the oven work? Thanks :-)
See below! Your answer is there!!
