The solution to your problem lies in one of the following three areas:
1.) Your lenovo n500 power charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Follow the steps to make it work on Android:
1. Switch off your N500 bluetooth headset
2. Press and hold the power button on N500 bluetooth headset for 6 seconds. (Remember, down press and leave the power button as it will switch on. We have to put it in discovery mode so pres and hold for 6 sec.)
3. The led will flash from blue to red.
Now on your android phone,
Go to settings, "Wireless & Network", Bluetooth
Switch on the bluetooth and scan for devices
You will see Noisehush N500. Click on the name and select pair
5. Enter "0000"as the passkey when phone when phone prompts.
6 Select the name again in phone and select connect.
The headset will be connected. If it asks to authorize, select always authorize.
Turn on your computer. Press F2, while the initial screen is displayed. The BIOS Setup Utility screen opens.
Boot priority order look for your had disk here. order should be 1. cd rom then 2. hard disk then 3. usb or network boot device. anything bellow doesn't really matter much.
I had the same problem. There is a small touchpad on the laptop, just above the Pause button, which turns the main mouse pad on and off. It is situated on the far right hand side (there are also touch buttons for the volume controls there), between the N500 logo and where the power supply jack fits in.
When you plug the USB charger to the unit, does the Orange LED light up?
If the light is ON, then the problem could be the charging circuit or the battery is defective.
If the light is OFF, then the USB port has a cold solder (Solder crack)
