Whatr is this error code?
Make sure your cold and hot water lines are hooked up properly. if that doesnt solve the problem than look at your water pressure and make sure the hoses arent kinked. other than that im not sure.
Please visit the below mentioned link to view a list of error codes of Frigidaire front load washer:
http://www.scribd.com/doc/8559708/Frigidaire-Affinity-Front-Load-Washer-Error-Codes
Thank you
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
This doesn't have e70 on the list! Not an Affinity.
E70 is the code that I am getting. It is not listed in the manual as an error code? anybody know what this code means?
