SOURCE: Bunn BT 10B -RANCID BUTTER in Resevoir!
Hi Tina - I'm no expert on melted butter in your coffee maker; but, I'd bet that the butter also got into the internal water tank where the water gets heated. Try going to the Bunn website: www.bunn.com , and click on their Customer Service link. You can either call their toll-free number or write to them with your problem from there.
Hope this helps!
SOURCE: Butter melted into top and down in to water container
mcdevito75 here, Try to clean your coffee maker by running a decanter full of white vinegar thru the system 2--3 times, then fesh water to rinse out the vinegar. Use a new or clean filter at the beginning of the vinegar treatment and after when you rinse with regular water.
SOURCE: RANCID BUTTER melted in Bunn Thermofresh resevoir vents!
There is one thing you can try first. With the machine filled with water and turned on, pour in 1 quart of white vinegar and let it sit in there for 2 hours. Then flush it back out with 8-10 carafes of water. If this doesn't correct the problem, then call customer service with the model and code date. This can be replaced under the warranty if it is under 3 years old or less. If it is over 3 years old, it can be replaced at a reduced price.
