Magnavox model #MWC24T5A Tv combo vcr dvd vcr tries to load tape with no tape in carrage. tv goes into shut down when vhs tape is inserted all funtions work untell tape ejected tries load tape when no tape is inserted cleaned mode switch and checked timing
SET HAS NO POWER WE HAVE 3SETS SAME PROBLEM
MODEL MWC24T5-B
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
