Computers & Internet Logo
andrea bayne Posted on Dec 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My toshiba laptop was recently swiped clean and rebooted running vista. Everything was running smooth.until i shut down the system. the next time at start up it didn't recognize any OS. the next t
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 42 Answers
  • Posted on Dec 09, 2012
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
42
Questions
0
Helped
8390
Points
131
I recommend reinstalling Vista, and replacing the Hard Drive as well. The errors being sporadic could be indicative of a hardware failure or a software failure and could be both in tandem.
5 Related Answers
caovatho2001
  • Posted on Jun 12, 2008
SOURCE: Toshiba laptop reboots when on AC Power
I don`t know.
Anonymous
  • 4 Answers
  • Posted on Sep 24, 2008
SOURCE: SYSTEM REBOOTS AFTER SHUTTING DOWN
It seems that when you formatted, you took your Bios settings with it. The latest bios can be obtained from toshibas website....Below is a direct link to the bios.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1976812xml&sliceId=&dialogID=51709196&stateId=0%200%2051707515
David Shaub
  • 2994 Answers
  • Posted on Oct 25, 2009
SOURCE: Nothing on powerup.
Open it up again and find the wire you blew off.
Anonymous
  • 466 Answers
  • Posted on Nov 24, 2009
SOURCE: cant install OS BOOTMGR is missing
Usually the installer should have a function to allow you to wipe the disk, or delete partitions.
If it doesn't, and you do not care about the hard disk content, and it is acceptable to wipe out the entire hard disk, you can do so in Linux.
(There is a utility which will do everything for you - Darik's Boot and Nuke, you find it at http://www.dban.org/ . I'm also giving you the "manual" instructions below, though).
Boot with Ubuntu Live, open Terminal, become root with 'su'.
Now you need to know how your disk is "seen" by Linux. Since you only have the one disk and nonexistent disks will fail, we can try all the likely hard disk names. The first command that does NOT fail saying "No such device" is the good one:
fdisk /dev/sda
fdisk /dev/hda
fdisk /dev/cciss/c0d0
fdisk /dev/rd/c0d0
fdisk /dev/ida/c0d0
One of these commands (likely the first or second) will give you a menu ending in "Command (m for help)". type "p" and press Enter to list partitions; there should be only one and it should be a Linux type, probably 83. If it isn't, stop - something's wrong. But it should be.
The first column will say something like "/dev/sda3". Note the number at the end, here "3". You'll likely have "1".
Now type, "d" and press Enter. You'll be asked which partition to delete. Type the same number you saw earlier. Type "w" and Enter to save changes and exit. Type "q" and Enter to exit without changes. The partition can still be recovered, but the disk is now "unlocked".
Reboot and install the OS of your choice. The previous hard disk contents will be permanently lost, and you'll get a shiny new empty partition with a working OS.
You can also erase the disk without using fdisk (but you still need to know how it's named, and for that you can use fdisk) by typing
dd if = /dev/zero of = /dev/sda bs=1M count = 12
Here we suppose the disk turned out to be /dev/sda.
This will write twelve megabytes of zeroes to the beginning of the disk, effectively wiping any OS information there could be there. All disk data are as good as lost. The disk is now, to all installing purposes, a perfect blank. Reboot and install the OS of your choice.
Just for the record, omitting "count" will zealously wipe out the whole hard disk surface, all partitions, all data, irretrievably (except using residual hysteresis detection equipment - doubt if even NSA would take the trouble). This can be handy when decommissioning computers.
There are also
Anonymous
  • 20 Answers
  • Posted on Jan 03, 2010
SOURCE: Toshiba Satellite A210 will not boot
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena8
How do i reboot my toshiba laptop?
Procedure to reboot your Toshiba laptop may vary depending upon which version of Windows you are using. Refer to the steps below that match your Windows version:
For Windows 8:
If there's a Power icon on your Start screen, tap or click it, and then tap or click "Restart". Else, follow the steps below:
1. Swipe in from the right edge of the screen, and then tap "Settings".
(If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, and then click "Settings".)
2. Tap or click "Power", and then tap or click "Restart".
For all other Windows versions:
1. Click the "Start" button
2. Click the arrow next to the Shut Down button
3. Click "Restart"
OR
1. Click "Start" button
2. Click "Shut Down"
3. Select "Restart" in the drop-down menu below "What do you want the computer to do?"
GuruAid.com
1helpful
My laptop hourglass constant
You are running to many processes, Shut down unnessary startup programs or running programs. Use Freeware CCLEANER found at : http://www.filehippo.com/download_ccleaner/, clean the junk from your machine, In the TOOLS section, STARTUP, disable ALL unnessary startup programs, reboot You didn't give your OS , Try these tips: http://www.pcmag.com/article2/0,2817,2364937,00.asp
Toshiba nb300 won't boot. PXE-E61 media test failure. check cable.
Hi,Thanks for using fixya,
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
If the problem is same please restore it ,
System Restore WIN XP systemrestore2 Backing up-System Protection and System Restore in Windows 7 Windows XP System Restore Is Easy to Use Use System Restore to Undo Changes if Problems Occur Using System Restore in XP - How-To Geek
System Restore in Windows 7 http://vlaurie.com/computers2/Articles/windows7-system-restore.htm http://vlaurie.com/computers2/Articles/windows7-system-restore.htm
Restore factorry setting.
For instruction follow the link
http://www.pcrecoverydisks.com/toshiba/toshiba-system-restore-vista/
For XP
press o (Zerro)and start laptop until start restore option
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. follow the link
http://en.kioskea.net/download/download-793-click-clean
again.
7) Click Next to Start recovery.
I hope you find this step by step solution helpful for you. If so, rate it up.
For VISTA
Pres f-8 start laptop until start restore option
RESET TOSHIBA TO FACTORY SETTINGS WITH BUILT IN BACK UP FILES
1Save your files first to an external memory storage like a memory stick or whatever u may have, plug in your laptop to the ac outlet.then....
2)Shut down your computer turn it on. then immediately press f8 repeatedly until it brings you directly to "advanced boot option".If you see the Windows Logo like "Windows Vista", you need to turn off your computer again and repeat pressing f8 simultaneously until you see the "advanced boot option" menu
4)Under "advanced boot option", highlight the option "repair your computer" and press "enter".
5)System recovery option menu will show up, select country and keyboard layout then press next.
6Then there is the option to log in as a local user so you can access recovery option,enter your password.
7)After that the "system recovery option" will show up and show these options
a)start up repair
b)system restore
c)window pc complete restore
d)windows memory diagnostic tool
e)command prompt
f) toshiba recovery wizard
8) Select "toshiba recovery wizard"
9) There will be a warning that "all files will be lost are you sure you want to continue?" Go on click whatever confirmation message u see.Al files wil be rewritten so there is nothing to worry .From there just go with the flow until recovery has finished.Your computer may restart automatically, thats normal. Hope u find this useful.Cheers
Hope this helps you.
Windows Vista won't install on my laptop.
Hello
Is this a clean install or an upgrade?Sounds like a upgrade.
You may need to format or wipe your hard drive clean,then try to install.
Try to boot from the vista disc and choose the clean install method.
Remember you will loose everything on your laptop doing this kind of install.
I have the same problem with my Toshiba too, prima facie, it looks like Toshiba and Vista don't make a good combo. I suspected this to be a pure hardware problem, but was disproven when I booted in safe mode. It does not have any problems with the AC Power on in Safe mode.
Vista Slow Shut Down
is vista the original operating system
Acer Aspire 3003 Strange Problem
Uninstall AVG and then download and install Avast Free version Antivirus. It is way better than AVG and MIGHT fix the problem.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
