The door to my freezer was left slightly ajar and now there is an alarm beeping every 4 seconds. I can't locate my user manual (of course). The sticker on the door says you can silence the alarm, but I can't find it's location! Where is it located, and is there a website where I can download a manual for future reference?
You can take the batteries out that power the alarm system. They are located through a small access panel/door front bottom right of the unit. If you bought the unit at Sears, you should call 1-800-4MYHOME and ask a technician if a replacement manual is available, or if they can direct you to a website for it.
The battery was the problem in ours. It was doing the same thing. We went through a whole bunch of stuff trying to figure it out too since we bought it as a floor model only two weeks ago. It's just a 9 volt battery.
Thank you for your post, friend!
Based off what you are describing it sounds like a possible issue within your control panel or door switch of your Frigidaire freezer, LFFH21F7HW6. You have completed a reset on your appliance by disconnecting power. I would recommend seeking assistance from a professional to properly diagnose and repair your freezer. Hope this is helpful. -Matt
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
The freezer door ws left open overnight. Next morning, the alarm was beeping, and water is dripping out of the drain pipe. The food inside was 1/2 defrosted. We closed the door, hit the quick freeze button, and the temp went down but has not yet recovered - it is now the next morning, and the temp is holding at 20 degrees inside. What to do? The freezer is 10 yrs old.
My freezer alarm keeps beeping. The power in our home blinked off and right back on during a storm, and the alarm keeps going off. The freezes seems to be working fine but the beeper keeps going off. We pulled the 9 volt out of the right front access panel and that worked until the next storm, and now its beeping again. Is there another battery located somewhere else?
Thanks
Denny
Our kenmore freezer alarm started beeping during a quick power outage in a storm. The beeper kept going off even after pushing the silencing button. So we removed access panel and took the 9 volt battery out and this seemed to work, but the following week after another storm, the beeper started beeping again, even with the battery out. Is there a second battery somewhere?
The power is on and except for the beeping, the freezer seems to be working fine
Thanks
Denny
Had the same problem. Freezer beeping constantly. Couldn't be stopped, until I read the note here to replace the battery inside of the battery container at the bottom right front of the freezer. Merely removing the battery did not solve the problem. But putting in a fresh battery sure did!
