Whirlpool WED9200SQ Electric Dryer Logo
Posted on Dec 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blower wheel how to take wheel off
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Dec 06, 2012
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629099
Points
28464
Take a look at the video below.
1helpful
BLOWER WHEEL BROKEN
In your instruction manual you should find a parts list, purchase a new blower wheel and install it. If it is an older unit it may be best to just replace it.
1helpful
I need to remove and clean furnace blower.
The entire blower and housing slides out you should find the mounting screws on each side of the blower housing they may be sheet metal screws either on the top or on the bottom. After you remove the two screws the blower should slide out. If you remove the blower wheel from the shaft make sure to tighten the lock screw on the flat side of the shaft. Another trick to pull the blower wheel from the shaft is loosen the lock screw and push the wheel in then clean the shaft wit fine sandpaper otherwise you can cause the wheel to jam up because dirt gets stuck between the wheel and the shaft
Almost constant rattling noise - think it is either the pump, or the fan. Is there a fix?
is one of 2 things you may have a piece of paper stocked in the blower assembly or you blower wheel is separating, you can check for any debris inside the blower wheel or check make sure the fins in the blower wheel have some play or you lost a balancing weight on the wheel is very easy to fix by replacing the blower wheel just measured the diameter and whit and go by your nearest WWGrainger and buy a new wheel will cost aprox. $50.00 to $70.00 if you have any questions please replay
1helpful
Need to replace heater blower motor. How do I get to it?
Behind the glove box. Please see my tip at http://www.fixya.com/cars/r6234839-doesn_t_heater_or_air_conditioner_blow . These are generic instructions. If you get stuck, please get back to me.
See instructions from autozone.com below.
REMOVAL & INSTALLATION
With Air Conditioning
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment door and glove compartment.
  3. Disconnect the blower motor wires from the blower motor resistor.
Fig. Fig. 1: Disconnect the blower motor wires from the blower motor resistor-1988 Escort
  1. Loosen the instrument panel at the lower right-hand side prior to removing the motor through the glove compartment opening.
  2. Remove the blower motor and mounting plate from the evaporator case.
  3. Rotate the motor until the mounting plate flat clears the edge of the glove compartment opening and remove the motor.
  4. Remove the hub clamp spring from the blower wheel hub. Then remove the blower wheel from the motor shaft.
Fig. Fig. 2: Unbolt the mounting plate from the case
Fig. Fig. 3: The motor can now be removed from the case
To install:
  1. If removed, assemble the blower wheel to the motor shaft and install the hub clamp.
  2. Install the motor and blower wheel assembly.
  3. Secure the instrument panel at the lower right-hand side.
  4. Connect the blower motor wires at the blower motor resistor.
  5. Install the glove compartment door and the glove compartment.
  6. Connect the negative battery cable.
  7. Check the system for proper operation.
Without Air Conditioning
  2. Remove the air inlet duct assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cable.
  6. Check the system for proper operation.
2helpful
How to replace a blower motor in a 1996 ford thunderbird lx
Removal
  1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
  1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
  1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
Installation
  1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
  1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
  1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
  1. Install the glove compartment liner.
1helpful
How do I replace the ac/heater blower moter?
Hope this helps....please don't forget to rate...thank you:
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Disengage the wire harness connectors from the retainer.
  4. Disconnect the blower motor electrical connector.
  5. Remove the motor cooling hose.
  6. Remove the screws and remove the blower motor.
    NOTE
    Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
  7. Remove the wheel from the blower motor as follows:
    • Remove the push clip.
    • Remove the wheel from the blower motor.
Blower motor cooling hose
Blower motor mounting plate
To install:
  1. Install or connect the following:
    • Wheel to the blower motor, if removed.
    • Blower motor and securely tighten the screws.
    • Motor cooling hose
    • Blower motor electrical connector
    • Wire harness retainers
4helpful
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
6helpful
Furnace blower motor vibration
Check for a loose set screw on the motor shaft for the blower wheel.
Check the blower wheel for a missing balance weight.
Check the blower wheel for a dust buildup in the blades.
Check the blower wheel for a broken fin blade.
Check the blower motor shaft for excessive play.(more than 1/4 inch of play).
Check mounting screws on the blower housing.
The blower wheel is making a lot of noise. How do
Remove the front face of the dryer and continue to disassemble the dryer until you have access to the blower wheel. The blower wheel is manufactured with a D shaped hole in the middle. If the whole on the inside of the blower wheel become rounded, then the wheel rotates at a different speed than your motor, causing the loud vibrations you have been hearing.
Using the pliers, remove the holding pin & blower wheel clamp. The clamp is the green ring and the pin is the small horse-shoe shaped pin with an arrow pointing to it.
Pull the old blower wheel off. You should see that the whole in the center is round rather than D-shaped.
Put the new blower wheel in place.
Replace the ring clamp & holding pin.
Re-assemble the dryer.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
