20 Most Recent Hunter 33201 Humidifier Questions & Answers
0answers
0answers
Manual vapor
Be the first to answer 2/8/2014 12:29:20 AM • Hunter 33201... • Posted on Feb 08, 2014Be the first to answer
manual
0answers
Dishwasher safe? did not
Please see the previous response posted at 2:20 pm ET.
5/18/2011 6:19:44 PM • Hunter 33201... • Answered on May 18, 2011
Why should I pay for a manual YOU did not provide
Please see previous response posted at 2:10pm ET.
5/18/2011 6:12:32 PM • Hunter 33201... • Answered on May 18, 2011
Where is the manual? what do you not understand?
Please see previous response from 2:10PM ET.
5/18/2011 6:11:54 PM • Hunter 33201... • Answered on May 18, 2011
I want the manual that YOU were supposed to
I'm sorry you didn't receive what you order. But, you're taking your wrath out on the wrong company. All 4 of your postings are on the FixYa web site, Not Hunter. The FixYa web site only provides help in troubleshooting and repairing many different things. FixYa does not sell or replace any products. Of the thousands of folks that seek help FixYa's website each month, occasionally a few mistake FixYa for the compamy they're having a problem with. Unfortunately, you posted your name and address for the entire world to see. Which is not wise in this day and time.
I understand your frustration with Hunter, but unfortunately, there's nothing we can do to help you with Hunter.
5/18/2011 6:10:45 PM • Hunter 33201... • Answered on May 18, 2011
0answers
Hello! I have a
Hi, Mark! It may be clogged with a calcium scale build up from the tap water you use. Unplug the unit and empty any water that is the tank.Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water. Mix enough to fill the tank. Let it soak for 2 to 3 hours and turn the unit ON. If it starts functioning as it should, allow it to run until the tank is 3/4's empty. If it doesn't operate as it should, allow it to soak overnight. And try again, following the procedure above. After it has run to the 3/4 empty point, turn the unit OFF. unplug it and dump the remaining solution. Refill the tank with Bottled Distilled Water and run again, for at least 2 hours. This with flush the system of the vinegar and water solution.
To avoid having this problem again, always use Bottled Distilled Water, rather than tap water.
Hope this helps to solve the problem. Have a Happy Easter!
4/22/2011 7:57:07 PM • Hunter 33201... • Answered on Apr 22, 2011
Humidifier makes room smell like a vacuum cleaner
The filter probably need to be changed if there is one.
3/12/2011 10:03:23 PM • Hunter 33201... • Answered on Mar 12, 2011
Everything powers up, but no output
If you had been using it up until now and you have hard water, the unit may be clogged. If this is the case, a 50.50 solution of White Vinegar and Water should clean the scale out. Just porr the solution in the tank and let it soak for a while. Turn the unit on and let the solution run thru the system. After it has almost emptied the tank, turn it off and empty the remainder of the solution and flush the system with clear water. In the future use bottled Distilled Water to avoid this problem.
2/17/2011 2:30:10 AM • Hunter 33201... • Answered on Feb 17, 2011
Used our humidifier last winter,
If it smells like plastic burning. Stop using it immediately. As there could be an electrical short or overheating of the unit. If doesn't smell like plastic burning, you'll need to be more descriptive of what the odor smells like.
2/9/2011 6:38:16 PM • Hunter 33201... • Answered on Feb 09, 2011
0answers
Hunter 33201 Humidifier Logo
42 questions posted
Top Hunter Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Hunter Humidifiers
  • Hunter Humidifiers
Most Popular Question
amp quot permawick
  • Humidifiers
