Not sure I understand what you mean by details? I tried to change windows internet explorer to another one it won/t except my password or user name. can you help me? this computer used to be my grandson's I/m wondering if there is a mixup! Any time I want add something or anything where you have to use user name or password the computer won't let me.
Wow, no details
NO PC stated of 10,000 HP models 1984 to now. wow !
like eg: I have HV DV-6-1234us PC laptop, or what the service tag tells you what it is... it is....
what OS, windows what XP? VISTA, W7/8/10?
what password, name just one. where , when, what ,
BIOS password before windows login?
windows login ?
or if running windows 10 , the windows live email login fails>
details
your GS gave it to you or just a loan.???? details matter big time on complex computers.
If you now own this PC why not reload the OS, using the HP F11 recovery key, 2006 and newer, no pc stated so no exact answers are possible at all.
if its not your pc, then create your own account
only your GS can do that after HE logs in.
click control panel
click users
click add user, you.
end.
http://www.pcdied.com/passwords.html
You need to change the user name and password from your grandson to new ones for you.
SOURCE: I forgot my Administrator Password
Well you got the right idea but the wrong tools and method
Download Hirens boot disc from www.phazeddl.com
Boot from the disc
that has all the tools you need to reset passwords, change passwords or anything of that nature, even recover files, its a computer persons dream disc if you ask me..
Good luck
SOURCE: Windows Explorer Details View problems.
Usually, the view is determined by the type of files within the folder. For example, when you are in the My Music folder, the Details view gives you columns like "Artist" and "Album", etc, whereas the My Documents folder has the more generic "Name", "Size", etc.
However, if you right click upon any column header (that's where it says "Name" or whatever), a menu comes up that allows you to choose which columns are displayed. And once you change a particular folder to display, THAT folder will then display those columns until you remove them. But any other folder will default to back to the standard settings unless you manually change it yourself.
SOURCE: windows xp is on computer, need to bypass codes to use it.
when the computer boots up hold down F-8 and then select "SAFE MODE' then log in a admin and the remove the passwords.. and restart and log in
SOURCE: i want to change the ip address on an okidata printer b4400.
Try the default username of admin and the default password of - OkiLAN and the password is supposed to be case sensitive. Let me know if that helps and good luck.
SOURCE: i forgot my password. i have changed it several
Re: the inability to use Windows etc. First make sure you logged on as an Administrator, if you're not change the permissions ( start->settings->Control Panel->User accounts, then make the changes needed).
As far as the lost password(s) visit www.magicaljellybean.com and download their key finder as you may need a key later on if you need to re-do major settings. Next head over to: http://www.loginrecovery.com and download the appropriate files to removable media if necessary, then run on your computer. If that doesn't recover the passwords check Tucows.com or Cnet.com for password recovery freeware.
Hope this helps.
for which operating system ????
Windows XP users
Change password
Note: Windows XP Home users can only change the Administrator password through Safe Mode Windows Vista and 7 users Change username
Change password
Windows 2000 users
Change password
Microsoft Windows 2000 users can change their username by pressing CTRL + ALT + DEL while in Windows to open the Windows Security window. From this window click the "Change Password" button
Enter your old password and the new password you wish to use.
Change username
In order to change the username of an account on Windows XP you will need to have an account with Administrator rights. If you're logged in as Administrator or have an account with Administrator rights, follow the below steps.
hope this helps
click start control panel Open User Accounts in Control Panel. On the
Users tab, click the name of the user whose password you want to change, and
then click Reset Password. In New password and Confirm new password, type the
new password, and then click OK. Notes You can change passwords only for local
computer accounts, such as guest, administrator, or accounts you create for
your computer. You cannot change your network logon password in User Accounts.
To change your own password, press CTRL ALT DELETE and then click Change
Password
also
if you are not the computer administrator and have not assigned a bios password
during the boot up process you will see on the screen for a short amount of
time press a certain key to enter set up Press and hold that key during the
boot up process to enter BIOS scroll down to set user password or supervisor
password you can change or remove your password from there also
click start control panel user
accounts on the users tab,click the name of the computer administrator you must
have full control can change the password there
Also
i have used this software and no that it works although
you might have to get a computer with an internet connection to download and
burn it to a disc
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that
allows you to repair, restore, or diagnose almost any computer problem also has
a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to
boot from the disc
During
the boot process you will see on the screen to press a certain key to enter
setup Press and hold that key during the boot up process to enter BIOS the
scroll down to advanced bios features press enter change your first boot device
to cd press escape then press f10 to save to cmos to restart (note after you
have removed your password you will have change first boot back to your hard drive)
http://www.filebuzz.com/findsoftware/Free_Password_Remover/1.html
you fill find a few password removal programs pay and
freeware
Hope this helps
