When I try and start my Loveno Ideapad S10-2 I get the following message: Realtek PCI Express Fast Ethernet Controller Series v1.17 (030506) PXE-E61: Media Test Failure, check cable PXE-M0F: Exiting pXE ROM. No bootable device -- insert boot disk and press any key I also tried going into the Setup Utility (F2) and it shows: Hard disk 1: None Hard disk 2: None I went to the Boot tab and changed the boot to USB CDROM : Optiarc DVD RW AD-7580S (DVD - Boot Disk) It kept telling me No harddisk found
SOURCE: computer locks when starting
I cannot be sure, but I think that this problem has something to do with having "boot from network adapter" enabled in your BIOS. If this is not the problem, then it might be another malfunctioning device, in which case, you will want to go into BIOS and disable everything except for what you need to get through the restore process(Disable USB ports, network adapter, PCMCIA card slot, etc.)
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: my laptop isnt working.as soon as u turn it on a
It goes to a network boot rather than booting straight to the HDD. restart your computer and press f2 immediatley. you are now on the BIOS page. check if your hard drive is detected and if not call Lenovo to have it replaced/repaired. if it is detected, after the PXE error, your computer should boot up just fine.
SOURCE: Windows is working normally and
It is your LAN driver which is creating problems.Download and install the necessary drivers for your Broadcom Netlink(if you have been given the "driver disc" with your laptop,use that to re-install the driver).If that doesn't work,I think your Broadcom Netlink is spoilt,get it repaired.
Thanks,
C Rahul
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Realtek
Drivers for
Realtek
Drivers for
Ethernet NIC
