Pride Value Line Revo Scooter 3 Wheel Logo
Gary Mound Posted on Dec 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The battery is charged the lights come on but the scooter will not move forward or backwards
Rob Hill
Level 3:
  • Pride Master 1,480 Answers
  • Posted on Dec 11, 2012
Rob Hill
Pride Master
Level 3:
Answers
1480
Questions
0
Helped
518211
Points
3838
Are there any flashing lights or beeping ?
Regards
5 Related Answers
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Jun 13, 2009
SOURCE: Battery fully charged, buzzing sound when i try to
check the FREEWHEEL LEVER at the rear of buggy to make sure it in the drive position, if you can push the buggy it not in drive mode.
Anonymous
  • 3085 Answers
  • Posted on Jun 18, 2009
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Jul 25, 2009
SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Oct 07, 2009
SOURCE: batteries are fully charged but won't go forward
it should show 24v not 13,5volts, sounds like you only measuring one battery,
Check the fuse under the seat and check the reset button,
Could be a bad connection to the batteries or to motor check the B+, B- voltages, should show around 24v.
Regards
GeWiz.
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Dec 15, 2009
SOURCE: I have a Pride Legnd..the scooter started loseing
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Testimonial: "Any insight to a problem is a positive step."
Riding my TGA Supersport mobility scooter when I paused at a road crossing, went to pull off and it wont move forward or backwards. Any ideas?
Question edited for clarity.
Question moved to Mobility Scooters albeit wrong make.
Likely to be a controller issue so needs dealer diagnosis. Others have had the same happen to them.
https://www.google.com/search?q=TGA+Supersport%2C+dead
Scooter not charging when plugged into the charger
measure the voltage of the batteries thru the charging socket of the scooter, the outside 2 pins.
2answers
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Can you help me try to figure out why my scooter will not move forward or backward? It is fully charged and the horn works.
I would get the batteries checked for power. Just because your charger shows fully charged quite often the batteries are low but enough power for lights or horn which does not take much power. i suspect bad batteries.
CTM HS-580 will not go, batteries are fully charged and no fault lights showing
H i, is there a click from the rear of the scooter when you push the lever to go forward or backwards ??
first of all disconnect one battery, now located the controller and follow the leads to the motor and brake , disconnect look at the connectors and refit , using contact cleaner if possible, making sure they are a good fit,,,
couple of points,,
The wiring from the throttle lever to the controller may be damaged so the controller never see's the pot move (resistance change) as it were..
At worse the controller may have failed, i offer a free testing service,, you only pay the return postage..
Regards
Rob
www.gewizrepairs.co.uk
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
2helpful
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Battery keeps a charge I have to push the scooter in gear and then it works
ok, that sounds like a load problem
check the motor brushes also it could be the speed pot has a intermittent connection, try moving it up and down as well as forward or backwards, it if bites while moving it up or down you need to replace the speedpot or wigwam as some people call it.
Make sure the connection between the batteries leading to the motor controller, normally a box or grey box are good, check the M+ M- lead connection the motor controller.
Regards
GeWiz.
1helpful
2answers
Have Zoom 220 HMV 3 wheel scooter. Charged battery in house socket. Shows green, turn key shows fully charged but will not move forward or backwards. Horn works.Moved don't have the manual. It is only 1...
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
