20 Most Recent
CTM Homecare CTM HS-580 4-Wheel Power Scooter Questions & Answers
What is the weight on the batterys
Lead acid batteries are not light but generate copious amounts of relatively inexpensive cost. Our battery technology is at least 100 years old but....................
Light is flashing 6 times
Hi,if the controller is a blue finned model called a Rhino, then the following applies...
6 OONAPU Out Of Neutral At Power Up. The throttle was not in the neutral position
when the scooter was turned on. The scooter does not drive.
• Return the throttle to neutral, turn the power off, and back on again.
• Throttle may need to be adjusted (see section 5.1.6).
• Check throttle wiring.
Regards
Rob
www.
gewizrepairs.co.uk
And please join me on Facebook
https://www.facebook.com/gewizrepairs
CTM HS-580 will not go, batteries are fully charged and no fault lights showing
H i, is there a click from the rear of the scooter when you push the lever to go forward or backwards ??
first of all disconnect one battery, now located the controller and follow the leads to the motor and brake , disconnect look at the connectors and refit , using contact cleaner if possible, making sure they are a good fit,,,
couple of points,,
The wiring from the throttle lever to the controller may be damaged so the controller never see's the pot move (resistance change) as it were..
At worse the controller may have failed, i offer a free testing service,, you only pay the return postage..
Regards
Rob
www.gewizrepairs.co.uk
What You Know About Fentanyl Detox?
Whether you've just overdosed on fentanyl or you're in recovery from a fentanyl addiction, you may be wondering what the best options are for fentanyl detox. This article will discuss some of the signs of an overdose, how to treat it, and some tips for recovering from a fentanyl overdose.
Symptoms of a fentanyl overdose
Symptoms of a fentanyl overdose during a detox are often severe. They can lead to *****. If you suspect that you have an overdose, it is important to seek medical help immediately.
The body's tolerance for fentanyl can decrease over time, so it is very easy for your body to overdose on the ****. In addition, if you use the **** with other drugs, the combination can be even more dangerous.
You can be aware of certain signs that you may be at risk for an overdose. They include slow breathing, pinpoint pupils, and choking sounds. When your body loses its oxygen, it can be extremely painful and can cause your heart to slow down. During an overdose, you can also become unconscious. The breathing can stop altogether.
Fentanyl is highly addictive. You can't stop using it without a lot of assistance. You'll need to go to a treatment center for a full recovery.
If you're addicted to fentanyl, you'll need to make a commitment to stay clean and sober. There are many different ways to treat the problem. Some of the most popular are cognitive behavioral therapy, which uses counseling to reprogram the brain and teach the patient how to live a sober life after treatment.
Which is good food for health?
A balanced diet of meat, fish, vegetables, fruit and nuts, with a moderate amount of beer and red wine plus lots of water.
How effectively to loose weight?
Losing weight effectively involves a combination of healthy eating and regular exercise. Consider exploring Dr. Nowzaradan's diet for guidance on sustainable weight loss practices. Additionally, prioritize adequate sleep, manage stress levels, and stay hydrated. Remember, consistency and patience are key on your weight loss journey. Learn more here:
https://betterme.world/articles/what-is-dr-nowzaradan-diet/. Good luck!
How to lose weight in 2 weeks - tips to follow
To lose weight,
* it is crucial to cut down the consumption of store-bought meals or ultra processed foods
* to start eating whole foods
* start including healthy fats and increase protein in your diet
Example meals:
Breakfast: Scrambled eggs and cheese (3 or 4 eggs)/cheese egg sandwich/egg toast/cheese egg omelette with some veggies and fruits (include avocado)
Lunch: Red meat/chicken with some rice and veggies
Dinner: Same as lunch
Can include coffee in the morning with less sugar. Try to avoid buying food from outside for 30 days and try this challenge to see drastic results. It is also recommended to bake your own bread. Cook your food using butter and NOT USING other oils. When you crave for sugar, try to snack on few dates stuffed with butter.
Need info on how to change bulbs on my sunquest pro 16s please
To change the bulbs on your SunQuest Pro 16S tanning bed, follow these steps: 1. Remove the acrylic shield and canopy grid, then turn each lamp a quarter turn to gently remove it from its holder
. 2. When reinstalling a lamp, insert the pins into the slots on top of the lamp holder and turn it a quarter turn
. Only use certified lamps for the SunQuest Pro 16SE
. Ensure proper power supply and breaker compatibility for the tanning bed
. For further guidance, you can refer to instructional videos like "How to change your tanning bed lamps"
or "Tanning Bed Lamp Replacement
My Buzzaround Xl by Golden Technology is fully charged but beeps when turned on and will not go. Tried taking out key and battery.
The number and pattern of beeps can help you identify the specific problem. For example, one beep means that the batteries are low, two beeps mean that the batteries are too low to operate, three beeps mean that the battery voltage is too high, and so on. You can find the full list of beep codes and their meanings on pages 13-18 of the manual.
To troubleshoot the issue, you will need a multi-meter and some basic tools. You can follow the instructions on pages 19-25 of the manual1 to check and replace the components that may be faulty, such as the drive wheel, the throttle pot, the battery, the circuit breaker, the controller, etc. You can also find some helpful diagrams and wiring information on page 10 of the manual
If you are not comfortable with performing these steps yourself, you can contact Golden Technologies for technical support or service. Their toll-free number is 800-624-6374,
GOLDEN BUZZAROUND XL SERVICE MANUAL Pdf Download ' ManualsLib
