Apex Digital Apex 40" Class 1080p 60Hz LCD TV - Black LD4077M Logo
Posted on Nov 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My remote doesn't work
Ty St
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 98 Answers
  • Posted on Nov 23, 2012
Ty St
Expert
Level 2:
Filmmaker:
Answers
98
Questions
Helped
32491
Points
345
Do you have any flashing indicator lights on the remote? If you don't you can verify your remote is sending IR signals by pointing a cell phone camera at the front of the remote and viewing through your cell phone screen while holding down a button on the remote. You should see the flashing IR light on your cell phone screen. If you do not see the flashing light either the batteries are no good, or the remote is not getting power due to a problem with the circuit board.
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Fan light turns on but doesn't turn off with remote also fan doesn't go on with remote
Make shure your batteries are good in the remote. Also some remotes have little dip switchers inside the battery cover that are either on or off. They must be in the same position as the dip switches on the receiver in the top canopy of the ceiling fan or the remote & receiver won't talk to each other. Apart from that you will probably need to replace the remote control & receiver unit.
1helpful
I am having a Bose Cinamate Digital Home Theater. Original remote of this was lost and bought a new Bose Solo/cinemate system universal remote. It doesn't function with the interface. Will it real
If you can't get this to work, I suggest you try to return the remote and buy and harmony remote. For me it worked very well with everything including old audio amps and you can configure your own activities.
No channel set up
Hi, try pressing the "closed caption" button on the remote. I hope that works. If this doesn't work try getting your TV's SE-R0305 Operating manual and reading through it and it might be able to help you. You will be surprised at how much information is in the TVs manual.
Hooked up my amp it has power but power light won't come on won't power up front speakers work and have sound but it doesn't move to back
Make sure the remote wire is hooked up. You can run a small wire from the power terminal to the remote terminal. If it powers up, then you have a remote wire problem. You can run a remote wire from the blue power antennae wire of the deck.
1helpful
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
I am not getting any picture from the tv. dvd and radio is working fine.
press the AV button on the remote control & if it doesn't work, look for the TV button on the remote control; & if it doesn't work again, check the booklet that comes w/ the tv upon purchasing it or bring your tv to where you bought it & make use of the guaranty voucher for them to fix it for free, (try those buttons first before bringing it back to the store).
1helpful
Hi, I have a Yamaha rx-v450 amp that won't change sound modes (stereo, hall, jazz, rock etc) from the remote control but it works from the buttons on the unit. I've checked my remote by pointing it...
Hi! Transmitting doesn't mean it's working, What you should do to test it is use a good quality universal remote such as a Logitech Harmony and first program the preset code for your receiver into the Universal Remote. If that works, you know your OEM remote has gone bad, at least for those buttons. If it doesn't then you you should attempt to have your Universal Remote "learn" the IR signals from your receiver's remote If the controls still don't work, there is a problem with either your IR receiver on your receiver or the the circuitry that proceesses the signals into commands. Good Luck!
Wont turn on
try the following;
disconnect your remote lead, connect the remote terminal to the positive terminal with a piece of wire. If the amp powers up then the remote output from your headunit is at fault. You can connect the remote lead to a switchable live at the headunit end to work around this problem. The amp will switch off when you switch the ignition off and vice versa.
If that doesn't work then there may be a problem with your positive feed so check your fuse (there should be one near your battery where you see the amp cable connect)
If that doesn't work, check how secure your earth lead is, kicker amps use a lot of power so these connections need to made to a clean metal surface. Scrape the paint away if you need to, make sure you have bare metal to connect to.
Lastly, if you have only just installed the amp, check that you have thick enough power cable. As I said before, the amp will draw a lot of current, if the main power cable is too thin then you may not be getting enough current to power the amp.
Hope this is helpful.
2answers
My keyless remote stop working & i tryed the step and it only work once. Please help
my keyless remote stop working,tried the step still no luck what to do next.
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
