20 Most Recent Bose Cinemate Digital Home Theater System Speaker Questions & Answers
2answers
Splice Bose speaker to connect to receiver
Each speaker has two 4 Ohm drivers. Each speaker has a connector with 4 pins. From left to right they are + - - +. Say 1 2 3 4 . If you want a 8 Ohm speaker connect 2 and 4 together. Now 1 goes to your amplifier (+) and 3 to your amplifier (-). In yor case join black with blue. Now red goes to the amplifier red and green to the amplifier black.
1/15/2023 4:03:59 PM • Bose Cinemate... • Answered on Jan 15, 2023
Which pins on a 13 pin plug for a bose powered acoustimass 25 series II module would i use just for subwoofer
I know this is late but might help someone plus I had to repair the audio input cable going from my acoustimass 25 series II to the Lifestyle 5 receiver. The 13 pin connecter cable terminates to 2 RCA jacks (red/white) one 3.5 mm jack and a female RCA which is the digital sound source. looking at the connector with the 13th pin on the bottom, I reference the pins from 1-13 starting at the top left: PIN 1 RCA (RED) center conductor PIN 2 RCA (RED) sleeve PIN 3 RCA (digital) sleeve PIN 4 RCA (digital) center conductor PIN 5 RCA (WHITE) sleeve PIN 6 not used *PIN 7 3.5mm RING (?????) PIN 8 3.5mm SLEEVE PIN 9 RCA (WHITE) center conducto PIN 10 not used PIN 11 not used PIN 12 3.5mm TIP PIN 13 not used * the 3.5 mm stereo jack is used for system control on the back of the lifestyle 5 receiver, the cable that terminates to the 3.5mm is a 3 conductor cable that terminates to PIN 8 & PIN 12 but PIN 7 only has continuity from the pin itself to the white cable (within the 3.5mm cable) but not all the way through to the 3.5mm ring (where i would assume it to terminate). Maybe this is where my problem is, I don't know but I spliced the cable right before the 3.5mm jack and there was continuity between PIN7 and the white cable that corresponds to the 3.5mm jack I just dont know where its terminating too. If anyone can confirm that it is supposed to terminate to the ring of the 3.5mm connector I would appreciate it.
6/3/2022 8:26:19 AM • Bose Cinemate... • Answered on Jun 03, 2022
3answers
Bose Cinemate Sr1 volume keeps auto turning off when not in use
Hi, All. First, thank you for suggestions posted. Next, I have unplugged both the subwoofer and the center channel speaker, left them unplugged for a minute or two, then re-plugged them in. However this did not correct the problem for me. When I pause the television for five or 10 minutes for example, the Bose volume automatically shuts off. This is a major inconvenience. I suppose if nobody can address this issue with the remedy here, I shall have to call Bose and see if they can assist. Any other ideas or suggestions? Meanwhile thank you very much.
9/25/2020 10:28:03 PM • Bose Cinemate... • Answered on Sep 25, 2020
No sound from Bose Cinemate system
Check if the speaker connector is firmly attached to the Acoustimass Module,if there is still no sound,the audio amplifier may have gone bad
10/27/2018 9:00:21 PM • Bose Cinemate... • Answered on Oct 27, 2018
2answers
Can't find remote for Bose
No, you need some sort of remote. Luckily this Bose uses IR for the remote and not RF. This means you might find a cheap universal remote that has a code for this. PC programmable remotes such as Logitech's Harmony, URC, and RTI remotes would definitely work.
If this was helpful, please rate!
10/23/2018 3:28:22 AM • Bose Cinemate... • Answered on Oct 23, 2018
3answers
I need the wiring diagram
There are just 4 wires connecting in that jack: 2 grounds and 2 hot. You can identify them yourself directly either just by looking at the rear pins (where and how they are soldered on the board) after you remove the back cover, or by testing them with an ohmmeter (to the metal side of the jack): the 2 ground wires will show 0, the empty ones will show infinite and the hot ones will show 0 in the moment when you connect it then the resistance will grow fast toward infinite (if after that you reverse the polarity of the test wires you will get initially a negative resistance).
8/22/2018 6:15:40 AM • Bose Cinemate... • Answered on Aug 22, 2018
I just bought a Panasonic
Check if that TV has headphone jack. If yes then you can buy adapter 3.5 mm to stereo RCA.
3/2/2018 5:31:53 PM • Bose Cinemate... • Answered on Mar 02, 2018
I have a Bose Cinemate
The manufacturer of the Optic cable will sell you a Switch plus two cables. Might be expensive.
1/15/2018 12:36:44 PM • Bose Cinemate... • Answered on Jan 15, 2018
I attached my Bose Cinemate
Hello Mmlaird, Sadly... (because Bose is small & easy to carry around)... ((probably new & still under warranty))... For the reasons stated... I would try the BOSE first... (however) "HUM' in an audio circuit (usu. listening to LINE Current) is caused by TWO electrical conditions: - Shabby wire routing - CHEESY capacitors... I have written a BOOK-FULL of complaints about SAMSUNG'S quality ($$) decision to use inexpensive ... CAPACITORS... (in my opinion). Over the years... I have recognized that SAMSUNG has become the poster child for bright pictures, competitive prices... and high FAILURE RATES for cheesy capacitors... Good news... Because of their competitive prices... They are quite popular... SPARE PARTS... and REPAIR kits on AMAZON (and litigation) bearing the SAMSUNG name have been quite interesting... Thusly... SAMSUNG PARTS ABOUND... (as needed)... By no means am I saying SAMSUNG is alone in these DECISIONS ... I'll only say BOSE is not a likely candidate for MARGINAL PERFORMANCE, design or CONSTRUCTION. Your choice... (my opinion). Hope I am helping Carnac the Magnificent
10/27/2017 10:37:49 AM • Bose Cinemate... • Answered on Oct 27, 2017
I have a Toshiba flatscren, just baught a Bose cinemate GS series 2 sound sytem, and only one speaker works, Returned it, got a new one and it does the same thing, It must be a settings issue on my T
The left audio channel pre-amplifier in your TV is not working. Fixing that is a job for a technician with an oscilloscope, or else you would have to replace the main board in the TV. If you connect another device (CD or MP3 player to your Bose sound system, I expect you will hear both speakers playing the sound from the other device.
10/19/2017 6:31:12 AM • Bose Cinemate... • Answered on Oct 19, 2017
3answers
Bose Cinemate remote stopped working
Ive had the same problem, basically happens anytime we lose power or if it gets unplugged. Great speakers, poor design. Im not having any luck this time. Gonna try leaving it unplugged longer, like days this time. The remote feels like the problem, any button just causes the TV/VCR/AUX/ect row to blink, can't program it or anything. Seems like this is a common problem
9/27/2017 8:38:50 PM • Bose Cinemate... • Answered on Sep 27, 2017
3answers
Bose cinemate will not power
Make sure your system is not plugged into a surge protector. Sometimes a surge protector will foul the system up, don't know why. lol. I fought with my system for 3 hours trying to get it to work, then moved it from my surge protector to the wall and it came on. If that doesn't work, try disconnecting the receiver module itself, wait 60 sec, then plug it back in. If that still does not solve the problem, I would suggest calling Bose Customer Service..
8/12/2017 7:32:15 AM • Bose Cinemate... • Answered on Aug 12, 2017
Digital cable TV sound does not match sound from 321 GS series III
Go to menu, select language choose appropriate language.
3/26/2017 12:45:42 AM • Bose Cinemate... • Answered on Mar 26, 2017
2answers
Trying to program charter remote with bose
Using Universal Electronics Charter Remote OCAP 4 Device, I was able to get the volume control to work using the final code in the code listing, 31933
3/20/2017 2:16:06 AM • Bose Cinemate... • Answered on Mar 20, 2017
2answers
Bose Home Theater system won't turn on
is the red light on?if it is just unplug power until the red light fades then pug back in then turn unit on
7/23/2016 6:20:10 PM • Bose Cinemate... • Answered on Jul 23, 2016
I have a universal remote it has no name on the remote but i found the numbers 00096c
BoseĀ® CineMateĀ® GS Series II Digital Home Theater Speaker System code that worked for my Charter Ocap-4 (C4000 & S4000) 4-Device HDTV DVR Cable Box Remote is 31933.
2/19/2016 11:41:38 AM • Bose Cinemate... • Answered on Feb 19, 2016
2answers
Device code for Samsung SMT-H3050 HD Cable Box
I use an old universal onkyo remote. 0035 Is a Panasonic code but worked the smt-h3050
Hope this helps
12/11/2015 6:23:24 AM • Bose Cinemate... • Answered on Dec 11, 2015
Bose universal remote code for dish receiver
00847 works for me
8/7/2015 7:24:15 AM • Bose Cinemate... • Answered on Aug 07, 2015
Bose Cinemate Digital Home Theater System Speaker Logo
528 questions posted
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
universal remote no name remote but
  • Audio Players & Recorders
