It has not been working, just stopped one day. Usually it's ATT internet issue, but this time they fixed everything on their end and it didn't work with the router. I have no idea how to fix the router. I'm suppose to check info on it, but don't have the ability. It won't let me get online even with the ethernet cable connected to fix it. I can probably call ATT to figure out how to get to the Netgear Log in despite this, but I don't know the username or password. I was going to reset it, but am warned to have a lot of information before I do(ex:ISP Username, ISP password, IP addresses, Wireless Security keys, opened ports, opened services), none of which I am sure of. I hear there is default info. for the model router, but am unable to find it online. Please help me get this router working again. I'm wasting netflix and xbox live money, plus if I ever get a laptop working, I'd really like to use it wirelessly.
SOURCE: problems with netgear wireless router
picolas and nannysboy,
You can setup your router any way you like after accessing it. You don't need software for NetGear. All you have to do to access the control panel is:
If you cannot connect by wireless, do the above while connected by a LAN cable (looks like a telephone cable, only fatter and wider).
The router should be connected as follows:
Please let me know if this helps. Good luck!
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
SOURCE: i lost my network security key, router is not working.
try this
username admin
password none
good luck
SOURCE: I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Testimonial: "I received great help! I got speedy replies and great information at a level I could always understand and proceed to work with. Great first experienc"
SOURCE: My cable internet provider has
put another lan card in pc
share your connection using ICS from network properties from first one
put a straight cable from pc to router
give the gateway of router to laptop
remember!! the class of ip's should be the same
you are done
