The stove has power to the automatic igniters, to the clock and the front display lights. The oven light is not working. When I turn the oven on it does not heat up, the fan starts up after a little while even though no heat is being generated
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
only the temp. down button won't work on my ge profile oven
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
It's a gas top but an electric oven, no heat is being generated in the electric oven.
In fact it's a Smeg CSA196
