20 Most Recent GE Profile JKP18 Electric Single Oven Questions & Answers
2answers
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
2/20/2014 11:06:00 PM • GE Profile JKP18... • Answered on Feb 20, 2014
0answers
0answers
0answers
manual
manual
2answers
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
2/21/2013 5:25:50 PM • GE Profile JKP18... • Answered on Feb 21, 2013
F4 error code on JKP18 oven
F4 = Shorted oven temperature sensor circuitHere is the sensor to order.
2/19/2013 6:04:12 PM • GE Profile JKP18... • Answered on Feb 19, 2013
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
5/20/2012 1:24:13 AM • GE Profile JKP18... • Answered on May 20, 2012
GE JBS55WOK4WW (SN: DM2068850)
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
8/11/2011 11:16:36 PM • GE Profile JKP18... • Answered on Aug 11, 2011
What is an F3 message
Hi jmjburns,
The F3 fault code description is an open or shorted oven temperature sensor. Please check the sensor harness and harness connection between oven sensor and oven control. If the wiring is ok and still encountering the same error, please replace the temperature sensor.
Hope it helps.
Thank you for using FixYa.
6/8/2011 3:08:11 AM • GE Profile JKP18... • Answered on Jun 08, 2011
I have a GE profile
Hi
This means a loose/broken wire on the oven temp sensor or the sensor is bad and should be replaced. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...please post back for further assistance.
Daniel
4/16/2011 6:59:40 PM • GE Profile JKP18... • Answered on Apr 16, 2011
My wall oven will heat up and then starts to blink
F3 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
3/9/2011 7:33:33 PM • GE Profile JKP18... • Answered on Mar 09, 2011
Flashing F3 error code
F3
Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven
sensor and oven control. Replace oven temperature sensor (RTD) if wiring is
ok.
2/23/2011 5:13:54 PM • GE Profile JKP18... • Answered on Feb 23, 2011
Flashing Locked light. Cannot open the oven door
The oven is locked because the temperature inside the oven has not dropped below the locking temperature. Press Clear/Off button and allow the oven to cool. Oven door should open once it has been cooled below the locking temp.
2/17/2011 10:31:53 PM • GE Profile JKP18... • Answered on Feb 17, 2011
I have a flashing locked
2/17/2011 10:29:44 PM • GE Profile JKP18... • Answered on Feb 17, 2011
GE Profile JKP18 Electric Single Oven Logo
44 questions posted
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
flashing f3 error code
  • Ovens
