Dell 1815dn All-In-One Laser Printer Logo
Posted on Nov 05, 2012
My dell 1815 has an internal error PJL_Main.C 1537 PLJT how do I fix this
Is this a circuit board problem?
1 Related Answer
Terry
  • 95 Answers
  • Posted on May 12, 2010
SOURCE: My DVD ROOM (DELL 1537)gets some physical error! I
Turn off computer
Locate a small hole in DVD drive lid.
Carefully insert a straightened paper clip.
Gently push & the lid should pop out.
Then you can open the drive & remove the CD
Restart the computer and see if drive is damaged or not
I'm having problems with my Dell Studio 1537,when
check the connectors from the main board to the screen if they are plugged well
My burner won't burn in my dell Studio 1537
Inside the DVD drive is a laser optical eye. This eye get's dirty.
Suggest remove ALL power, then open DVD drive tray. Use a can of compressed air for computers to clean, and aim down towards the bottom of the tray.
(Remove AC adapter {Charger}, and Battery)
Disk cleaners have the tendency to wipe the 'gunk' off, then wipe it back on.
Also make sure you still have burner software. Nothing like going to use the DVD burner one day, only to find the Nero burner software was just a trial.
http://infrarecorder.org/
http://infrarecorder.org/?page_id=4
http://infrarecorder.org/images/screenshot_main.png
It's FREE, and NOT a trial.
Plus a DVD drive is mechanical. Wears out over time. Has a 'Life Cycle'.
http://www.laptopdvdrw.com/dell-studio-1537-slot-cd-dvd-rw-burner-drive-p-37670.html
Just an example. You may find a better price from another reputable dealer.
The DVD drive is held in with ONE screw,
Dell Support > Studio 1537 Notebook PC > Main Support page,
http://www.dell.com/support/troubleshooting/us/en/19/Product/studio-1537
Dell Support > Studio 1537 Notebook PC > Service Manual >
Click on Manuals & Documentation > Dell Studio 1535 / 1536 / 1537 Service Manual (1103KB)
For additional questions please post in a Comment.
Regards,
joecoolvette
2answers
Kyocera 1815 la y sale error c6020
The error means - Abnormally high fixing unit thermistor temperature.
Can be caused by Shorted thermistor or Broken heater control circuit on the power supply board.
1helpful
What is the most common problem with A Dell Studio 1537 LED backlit LCD not lighting up?
LCD inverter board. They're pretty simple to replace and cost only bout $10-$15 on Ebay. If you do it yourself just be careful taking off the plastic bezel from the screen.
My dvd room (dell 1537)gets some physical error! I injected a cd disk; but it does not read... And i find no way to take the disk out.
Turn off computer
1helpful
Studio 1537 upgrade from P8400 to T9400 problem!
First of all go to support.dell.com and click drivers and download. make sure you update al your driver especially video,
chipset and system software.
I've gotten this before and it might be memory issue with video when you start your system start tapping F12 and select the boot to Utility Partition or Diagnostics.select system test and and choose the extended test. google the error codes if any . I usually get this due to a video driver.
1helpful
Forget my hdd password on DELL 1537 hdd passwore error code is (05758) system service tag code is (9HGR64J)
Hi, your best bet is to go to the Dell website and enter your service tag in support page.
If you need more help, please ask.
regards - Anthony
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
