20 Most Recent Dell Studio 1537 Notebook Questions & Answers
Help... I am stupid!
if the computer is over 2 years old replace the harddrive with a SSD and reinstall windows
4/24/2019 4:32:00 PM • Dell Studio 1537... • Answered on Apr 24, 2019
CAN I CHANGE MY MOTHERBOARD 2 INCREASE THE PERFORMANCE OF MY DELL STUDIO 1450
Very hard and expensive to replace a motherBoard on a laptop. If you have performance problem try to clean the computer from all malware, using malwarebyteantimalware . the ferr version is excellent. After disable all program that open when you start your computer. CCleaner has the option to do this and it will also delete unnessessary files ... If you still have preformance problem you could change the memory chip in your laptop for a bigger one ... but usually the clean-up is enough
12/14/2014 2:13:55 PM • Dell Studio 1537... • Answered on Dec 14, 2014
Motherboard is expensive. It's better to buy a new computer rather than a motherboard.If you want to increase performance, then upgrade the RAM stick and harddrive.
5/8/2013 11:04:34 AM • Dell Studio 1537... • Answered on May 08, 2013
Can i upgrade my Dell studio 1537 laptop's video graphics
The Dell Studio 1537 has 2 video options, UMA Intel and ATI HD3600. Both solutions are built into the motherboard and essentially not upgradeable
5/8/2013 9:12:31 AM • Dell Studio 1537... • Answered on May 08, 2013
2answers
The display has turned sideways so i have to tilt
hehe, this used to be something naughty male techs did to female techs in the course to show superiority.
It is possible to rotate the whole desktop even upside down Right clicking on desktop ( box appears) select Graphics Options and Rotate to the degree that puts it all back the right way. Enjoy!
please rate my help++++Thanks for using FIXYA
4/6/2013 4:32:16 PM • Dell Studio 1537... • Answered on Apr 06, 2013
I've read about something similar on cnet.com - look here ("Plugged in, not charging") - espesially the very first solution.Hope it helps.
6/21/2012 6:45:14 AM • Dell Studio 1537... • Answered on Jun 21, 2012
Finding a password
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-http://www.hirensbootcd.net/http://67.20.82.163/
5/13/2012 10:53:10 AM • Dell Studio 1537... • Answered on May 13, 2012
Dell STUDIO 1537 black screen on first boot up ??
The inverter maybe faulty, it supplies high voltage to the CCFL lamp and would cause the screen to be black.Since it was just repaired, I suggest you return it to Dell to have it repaired under warranty.
5/10/2012 6:23:17 AM • Dell Studio 1537... • Answered on May 10, 2012
I have a Dell Studio
Go to Computer (or My Computer) and locate the disk drive probably below the Local Disk (C:). It is usually the one labelled drive D (D:/). Right click on it and select eject, This will eject it. Be sure to like my answer if it works, thank you :)
7/3/2011 8:43:12 PM • Dell Studio 1537... • Answered on Jul 03, 2011
My dell studio laptop 1537 not getting turned on
check the charger, if it's fine, you have a motherboard problem. Replace it at dell authorized service center
6/23/2011 5:14:21 AM • Dell Studio 1537... • Answered on Jun 23, 2011
Dell 1537 laptop - power
The red wire = + ve wire
black wire= - ve wire
brown wire=ground
5/24/2011 4:39:12 PM • Dell Studio 1537... • Answered on May 24, 2011
0answers
When i type this: 1. Click Start, and in the
you need to reinstall the operating system
1/23/2011 8:11:08 PM • Dell Studio 1537... • Answered on Jan 23, 2011
Caps Lock Light not working. It use to.
Probably needs keyboard replaced. To verify, try plugging in a USB keyboard and see if Cap lights function.
1/5/2011 1:11:47 AM • Dell Studio 1537... • Answered on Jan 05, 2011
My Video just went black.. I plugged into the
Hi There,
You've done the exact troubleshooting necessary to narrow down your problem to only 1 real possibilty.
Your video card has failed. If the 1537 operates off a "discrete" (separate and detachable) video card, it can be replaced fairly easily. If it's of the sort which is BGA (BAll Grid Array), meaning that it was soldered to the motherboard with high tech robotics (the video card attached on almost microscopic balls of extremely dense high melting point solder), then the only practical solution is to replace the motherboard.
I wish you well,
Selk
11/6/2010 7:05:12 AM • Dell Studio 1537... • Answered on Nov 06, 2010
On screen display of dell ac power adapter not
2 possible causes, faulty adapter or faulty motherboard. try to update the BIOS if applicable. If this does not work, attempt to test the adapter on another laptop to confirm if it is working, or try a confirmed working adapter with your laptop. If same issue with another adapter, or if your adapter works with another laptop, it will be a motherboard problem. If the adapter fails on another laptop or if another adapter works with your laptop, you'll need to get a new adapter. Hope this sheds some light. Feel free to rate the usefulness of the information.
11/4/2010 9:23:58 AM • Dell Studio 1537... • Answered on Nov 04, 2010
Dell Studio 1537 screen black,
Could be either the inverter board or the LCD screen cable.
9/19/2010 12:19:24 AM • Dell Studio 1537... • Answered on Sep 19, 2010
2answers
Dell Studio 1537 Notebook Logo
42 questions posted
Popular Products
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Studio Dell
  • Studio Dell
Most Popular Question
dell 1537 laptop power
  • Computers & Internet
