Hi there, I am have been doing some research and I can not decide from any of these to models: Either the Life Fitness T3 with Track console: http://www.fitnessinn.co.uk/life-fitness-t3-treadmill-with-track-console-new-2012.html Or the Life Fitness T5-0: http://www.fitnessinn.co.uk/life-fitness-t5-0-treadmill.html What would you guys do? I have been told the T3 is quite a nice one but the T5 seems a bit better. The thing is that I want to get some free weights and maybe a multigym and adding a bit here and a bit there... and it will end up being quite costly. Help :)
SOURCE: FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
http://www.loveawake.com/results/?form_n...|seeking_for^equal=2&t1|***^equal=1&age_from=30&age_to=56&t1|country^equal=&t1|state^equal=&t1|city^equal=&t1|photos^eqmore=0&submit=Search&page=7
