I have a Zanussi Electrolux model ZEBF250W and have had it for approx 4 years. It has a problem where the top half (fridge part) isn't cooling anymore? The bottom half (freezer) is working still.
I noticed at the back of the fridge/freezer, there's an insulated pipe (I think) which has ice forming around it in small sections (where the pipe comes out of the unit).
Is it a problem easily solved/fixed - or should I buy a new unit??
Kind thanks.
9 times out of ten, when the freezer portion works, and the refrigerator portion doesn't, it is the evaporator fan that is the problem. I am not familiar with that model, so I do not know where the fan is located. But there is a fan that blows cold air from the freezer into the fridge portion. Usually, a fan blade is just stuck, and just needs to be repositioned or the bearing the motor spins on could be frozen or rusty. I little household oil usually does the trick, or you might need a new fan motor.
Another possible cause is the ice that can build up. If there is ice blocking the air's path it will have the same result. You said you had defrosted the unit, so this is not likely in your case
Short term solution switching the whole unt of for a day and it seems to work for a month or two till it happens again
If ice is buiding up its usually due to the defrost system not working. There is a timer located at the rear to the right of the compressor which every so often turns on the defrost cycle. To check it , remove the plastic box and with a screwdriver turn the clock around until it clicks. This is then on the defrost cycle. After a short time water should start to drip out onto the top of the compressor. If it does not , the heater may be faulty. If it fails to stop defrosting and move back to freezing , the timer is faulty.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Just thought I'd add - I have tried defrosting the unit, and left it unplugged for about a week.
Thanks.
Kind thanks Chuck for your help buddy!
I know where the fan is located - so I'll have a look at it today to see if it's stuck etc.
If it appears fine - I think I might just buy a new unit.
Kind thanks for your help and a Happy new year to you!
regards.
HI AGAIN.
I'VE CHECKED THE FAN - AND IT IS WORKING AND SPINNING FREELY. I'VE LEFT THE FAN COVER OFF - SO I CAN MONITOR IT.
THE GREEN LIGHT HAS STOPPED FLASHING (BUT THIS NORMALLY FLASHES AGAIN AFTER A DAY OR SO). THE AIR FLOW IN THE TOP HALF - I'VE OPENED IT TO THE MAX, AND I'VE TURNED THE OUTER TEMP CONTROL TO MAX - TO SEE WHETHER THE TOP HALF COOLS OR NOT.
ANY OTHER INFO WOULD BE GREATLY APPRECIATED.
THANKS
freezer ok fridge not getting cold, fan working.
