20 Most Recent Zanussi Z32 / 5 Top Freezer Refrigerator Questions & Answers
Freezer fine, fridge too cold!
You need a new fridge side Thermistor. If that doesn't solve the problem, then replace the Damper Actuator.
1/9/2018 4:08:56 AM • Zanussi Z32 / 5... • Answered on Jan 09, 2018
Fridge freezer keeps tripping the
Hi
Is it plugged into a dedicated line? Meaning no other appliance or anything else is on this same circuit. If it is on a dedicated circuit it could be that the motor or compressor is going bad or else there is a short somewhere. Get an engineer to do an earth resistance check on the defrost circuit and the compressor, unless you know how to do it yourself.
Please get back to us if you have further query else please accept the suggestion. Thank you for contacting fixya.com
8/2/2011 8:55:37 AM • Zanussi Z32 / 5... • Answered on Aug 02, 2011
2answers
My refrigerator is too cold.
your thermo stat is probably stuck , suggest replacing it with new one
1/27/2011 12:01:55 PM • Zanussi Z32 / 5... • Answered on Jan 27, 2011
Hi. I have a Zanussi
Well, you need to clean the Refrigerator Coils...
Please follow the below steps -
Pull the refrigerator away from the wall and other appliances and shut off the electricity by unplugging the power cord. For built-in refrigerators, turn the respective circuit breaker off.
Remove both (or just the kick plate, in built-in models) cover plates to expose the condenser coils. Most plates come off without any disassembly of fasteners; others are screwed on, especially the back plate.
3. If a vacuum is available, use the long, narrow hose attachment to clean out the debris in and around the coils.
Using a bottle brush or a dryer vent brush will help immensely; especially if your refrigerator is old and hasn’t been cleaned for a very long time.
If a vacuum is not available, using a bottle brush or a dryer vent brush will do the trick just as well.
4. After cleaning, restore the cover plates onto the refrigerator and turn the power back on.
I hope this will do the job....
Good Luck!!
Thanks
8/15/2009 5:05:09 PM • Zanussi Z32 / 5... • Answered on Aug 15, 2009
Zanussi fridge freezer not working.
You will need a service call for diagnosis and repair. It could be a faulty thermistor (electronic temperature sensor), or it is low on refrigerant gas and needs a top up. Gas is the most likely reason. Make sure the freezer isn't on an Eco Mode that only deep chills the bottom, and useful if the freezer is nearly empty. https://www.google.com/search?q=Zanussi+integrated+fridge+freezer.+The+fridge+seems+too+cold+and+has+frost+at+the+back and https://www.google.com/search?q=Zanussi+integrated+fridge+freezer.+freezer+only+cold+at+bottom ..
8/7/2023 3:55:00 PM • Zanussi... • Answered on Aug 07, 2023
Zanussi zx97/5W Fridge keeps getting warm...
If your Zanussi ZX97/5W fridge keeps getting warm, there could be a few possible causes:
  1. Thermostat malfunction: The thermostat controls the temperature inside the fridge. If it is malfunctioning, it may not be able to maintain the correct temperature, causing the fridge to get warm.
  2. Dirty condenser coils: The condenser coils are responsible for removing heat from the fridge. If they are dirty, they will not be able to function properly, causing the fridge to get warm.
  3. Door seal issue: If the door seal is damaged or not sealing properly, it can allow warm air to enter the fridge, causing the temperature to rise.
  4. Fan motor issue: The fan motor is responsible for circulating the air inside the fridge. If it is not working properly, it may not be able to circulate the air, causing the temperature to rise.
  5. Temperature control issue: If the temperature control is not set correctly, the fridge will not be able to maintain the correct temperature.
7/18/2023 9:57:51 PM • Zanussi... • Answered on Jul 18, 2023
2answers
Zanussi ZX97/5SI fridge/freezer. Fridge part no
If the fridge part of your Zanussi ZX97/5SI fridge/freezer is no longer keeping cool, while the freezer part is still working fine, there could be a few possible causes:
  2. Air circulation problem: If the air is not circulating properly inside the fridge, it may not be able to maintain the correct temperature. This could be caused by a dirty or blocked air vent, a malfunctioning fan motor, or a problem with the door seal.
  3. Evaporator coils are iced up: The evaporator coils are responsible for removing heat from the fridge. If they become iced up, they will not be able to function properly, causing the fridge to get warm.
  4. Compressor issue: The compressor is responsible for pumping refrigerant through the cooling system. If the compressor is not working properly, it may not be able to pump refrigerant through the system, causing the fridge to get warm.
  5. A malfunctioning control board: The control board is responsible for managing the functions of the refrigerator, if it's malfunctioning it may cause the fridge not to maintain the correct temperature.
1/25/2023 5:13:30 PM • Zanussi... • Answered on Jan 25, 2023
How can I get to the evaporator fan in zanussi fridge freezer ZX97/5SI
Odds are the fan is in the freezer side...For some reason the cold air isn't getting to the freezer. In the back of the freeze part shoud be a channel that the cold air blows thru to cool the refer. Either the fan is not working...or working slow. or something is blocking the path of cold air. Dig into it. Shoud be an easy fix.
11/22/2022 5:01:33 PM • Zanussi... • Answered on Nov 22, 2022
I just defrosted a Zanussi fridge/freezer, turned it back on but won't temperature control any more.
'regulator'? Do you mean the thermostat? Modern fridge freezer thermostats don't make any noise because they are electronic and use a Thermistor electronic sensor. Is the compressor and fan running? It takes about 2 hours to get back to temperature. The control knob should always be set midway to start, then you adjust +/- depending on the internal temperature..
7/16/2022 1:57:43 PM • Zanussi... • Answered on Jul 16, 2022
Zanussi ZENB 2925 Fridge Freezer, 10 years old: Freezer working OK but fridge not working. Any Ideas.
look for ice build up behind freezer - defrost cycle transducer or defrost circuit fan that blows cold air from freezer to fridge - see if it is working or jammed on something put into freezer .
10/3/2018 4:46:54 AM • Zanussi... • Answered on Oct 03, 2018
Zanussi ZENB 2925 Fridge Freezer 10 years old. Freezer working OK but fridge not working. Any Ideas.
Evaporator fan may not be working or may be a defrost problem.
10/2/2018 9:29:09 PM • Zanussi... • Answered on Oct 02, 2018
Zanussi Z32 / 5 Top Freezer Refrigerator Logo
9 questions posted
Top Zanussi Refrigerators Experts
ZJ Limited
ZJ Limited
vince
Johnny 1000
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Refrigerators
Most Popular Question
freezer fine fridge cold
  • Refrigerators
