20 Most Recent Zanussi ZI921 / 8FF Bottom Freezer Refrigerator Questions & Answers
2answers
Noise from freezer
Sounds like the compressor unit has gone out. It will need to be replaced. When you call somebody to come out and fix it, make sure its a company that is trusted and bonded. Call around and get estimates.
3/1/2013 12:44:09 AM • Zanussi ZI921 /... • Answered on Mar 01, 2013
My Zanussi Fridge Freezer ZI921/8FF
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
9/6/2011 2:42:19 AM • Zanussi ZI921 /... • Answered on Sep 06, 2011
The freezer do will not
sounds like u have a tray in wrong place .......or back to front
2/27/2011 7:21:20 PM • Zanussi ZI921 /... • Answered on Feb 27, 2011
The freezer is working OK
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
11/28/2010 2:51:14 AM • Zanussi ZI921 /... • Answered on Nov 28, 2010
I have a zanussi ZI 920/9K and the fridge has
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
7/5/2010 8:56:07 PM • Zanussi ZI921 /... • Answered on Jul 05, 2010
0answers
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
1/3/2009 3:56:52 PM • Zanussi ZI921 /... • Answered on Jan 03, 2009
2answers
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
10/8/2008 8:00:25 PM • Zanussi ZI921 /... • Answered on Oct 08, 2008
0answers
Zanussi fridge freezer not working.
You will need a service call for diagnosis and repair. It could be a faulty thermistor (electronic temperature sensor), or it is low on refrigerant gas and needs a top up. Gas is the most likely reason. Make sure the freezer isn't on an Eco Mode that only deep chills the bottom, and useful if the freezer is nearly empty. https://www.google.com/search?q=Zanussi+integrated+fridge+freezer.+The+fridge+seems+too+cold+and+has+frost+at+the+back and https://www.google.com/search?q=Zanussi+integrated+fridge+freezer.+freezer+only+cold+at+bottom ..
8/7/2023 3:55:00 PM • Zanussi... • Answered on Aug 07, 2023
Zanussi zx97/5W Fridge keeps getting warm...
If your Zanussi ZX97/5W fridge keeps getting warm, there could be a few possible causes:
  1. Thermostat malfunction: The thermostat controls the temperature inside the fridge. If it is malfunctioning, it may not be able to maintain the correct temperature, causing the fridge to get warm.
  2. Dirty condenser coils: The condenser coils are responsible for removing heat from the fridge. If they are dirty, they will not be able to function properly, causing the fridge to get warm.
  3. Door seal issue: If the door seal is damaged or not sealing properly, it can allow warm air to enter the fridge, causing the temperature to rise.
  4. Fan motor issue: The fan motor is responsible for circulating the air inside the fridge. If it is not working properly, it may not be able to circulate the air, causing the temperature to rise.
  5. Temperature control issue: If the temperature control is not set correctly, the fridge will not be able to maintain the correct temperature.
7/18/2023 9:57:51 PM • Zanussi... • Answered on Jul 18, 2023
Zanussi ZI921 / 8FF Bottom Freezer Refrigerator Logo
26 questions posted
Top Zanussi Refrigerators Experts
ZJ Limited
ZJ Limited
vince
Johnny 1000
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Refrigerators
Most Popular Question
zanussi electrolux frost free fridge
  • Refrigerators
