20 Most Recent Zanussi ZX56 / 4 Bottom Freezer Refrigerator Questions & Answers
How to defrost my freezer
What is the model number?
10/19/2012 2:12:32 AM • Zanussi ZX56 / 4... • Answered on Oct 19, 2012
Fridge not cooling on fridgefreezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/19/2011 3:17:05 AM • Zanussi ZX56 / 4... • Answered on Sep 19, 2011
Compresor working and its body
try cleaning your condensor coils.
3/26/2011 12:55:05 PM • Zanussi ZX56 / 4... • Answered on Mar 26, 2011
Zanussi zx 56/4 The lower freezer
did you find the problem because mine is doing the same thing?
1/13/2011 4:37:38 PM • Zanussi ZX56 / 4... • Answered on Jan 13, 2011
I have a zanussi fridge freezer model no zx56/4w.
you need to totally defrost the fridge/freezer and start as if it were new and dry.allow 24 hours for the unit to settle to the correct temp.
please leave feed back
9/16/2010 8:12:45 PM • Zanussi ZX56 / 4... • Answered on Sep 16, 2010
I was defrosting it with hot water and a hammer
sounds like you may have broke the freon line do not plug in until you get leak fixed and filled with freon
11/7/2009 5:21:28 PM • Zanussi ZX56 / 4... • Answered on Nov 07, 2009
Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
3/19/2009 12:43:39 AM • Zanussi ZX56 / 4... • Answered on Mar 19, 2009
2answers
Fridge/Frezer stop working
Can you tell if the compressor (black soccer ball looking thing in the rear of the unit) is running? Is it really hot? Is the little fan running near it? If the compressor isn't running it won't cool. Also check that the coil in the freezer section isn't frozen solid blocking all air flow inside the unit. The other thing is that the defrost cycle may be "stuck" so it thinks it should be defrosting (therefore not running the compressor, etc.) Lots of things to check but that info will help decide which way to go so post what you find please.
7/2/2007 12:17:00 PM • Zanussi ZX56 / 4... • Answered on Jul 02, 2007
Zanussi fridge freezer not working.
You will need a service call for diagnosis and repair. It could be a faulty thermistor (electronic temperature sensor), or it is low on refrigerant gas and needs a top up. Gas is the most likely reason. Make sure the freezer isn't on an Eco Mode that only deep chills the bottom, and useful if the freezer is nearly empty. https://www.google.com/search?q=Zanussi+integrated+fridge+freezer.+The+fridge+seems+too+cold+and+has+frost+at+the+back and https://www.google.com/search?q=Zanussi+integrated+fridge+freezer.+freezer+only+cold+at+bottom ..
8/7/2023 3:55:00 PM • Zanussi... • Answered on Aug 07, 2023
Zanussi zx97/5W Fridge keeps getting warm...
If your Zanussi ZX97/5W fridge keeps getting warm, there could be a few possible causes:
  1. Thermostat malfunction: The thermostat controls the temperature inside the fridge. If it is malfunctioning, it may not be able to maintain the correct temperature, causing the fridge to get warm.
  2. Dirty condenser coils: The condenser coils are responsible for removing heat from the fridge. If they are dirty, they will not be able to function properly, causing the fridge to get warm.
  3. Door seal issue: If the door seal is damaged or not sealing properly, it can allow warm air to enter the fridge, causing the temperature to rise.
  4. Fan motor issue: The fan motor is responsible for circulating the air inside the fridge. If it is not working properly, it may not be able to circulate the air, causing the temperature to rise.
  5. Temperature control issue: If the temperature control is not set correctly, the fridge will not be able to maintain the correct temperature.
7/18/2023 9:57:51 PM • Zanussi... • Answered on Jul 18, 2023
2answers
Zanussi ZX97/5SI fridge/freezer. Fridge part no
If the fridge part of your Zanussi ZX97/5SI fridge/freezer is no longer keeping cool, while the freezer part is still working fine, there could be a few possible causes:
  2. Air circulation problem: If the air is not circulating properly inside the fridge, it may not be able to maintain the correct temperature. This could be caused by a dirty or blocked air vent, a malfunctioning fan motor, or a problem with the door seal.
  3. Evaporator coils are iced up: The evaporator coils are responsible for removing heat from the fridge. If they become iced up, they will not be able to function properly, causing the fridge to get warm.
  4. Compressor issue: The compressor is responsible for pumping refrigerant through the cooling system. If the compressor is not working properly, it may not be able to pump refrigerant through the system, causing the fridge to get warm.
  5. A malfunctioning control board: The control board is responsible for managing the functions of the refrigerator, if it's malfunctioning it may cause the fridge not to maintain the correct temperature.
1/25/2023 5:13:30 PM • Zanussi... • Answered on Jan 25, 2023
How can I get to the evaporator fan in zanussi fridge freezer ZX97/5SI
Odds are the fan is in the freezer side...For some reason the cold air isn't getting to the freezer. In the back of the freeze part shoud be a channel that the cold air blows thru to cool the refer. Either the fan is not working...or working slow. or something is blocking the path of cold air. Dig into it. Shoud be an easy fix.
11/22/2022 5:01:33 PM • Zanussi... • Answered on Nov 22, 2022
Zanussi ZX56 / 4 Bottom Freezer Refrigerator Logo
20 questions posted
Top Zanussi Refrigerators Experts
ZJ Limited
ZJ Limited
vince
Johnny 1000
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Refrigerators
Most Popular Question
defrosting hot water hammer
  • Refrigerators
