SOURCE: Initialization Error
try pressing the 2 green buttons to reset the unit . if you get lucky and it turns on, immediately follow the steps to update your firmware on this website http://ampin.wordpress.com/2007/03/02/nikon-d40-firmware-upgrade/ , otherwise you will need to take the camera to an authorized repair center . :)
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
SOURCE: nikon d40
Try removing the battery and reinstalling it. Also try reformatting the memory card.
SOURCE: faulty nikon d40
I had the same error message, the camera is less then a year old, however, I was taking up to 800 pictires every weekend of my kids soccer games, then a 6 month trip to the Pursian Gulf, that is when it started, I got back home, took it right in, and one year later after a few visits and calls trying to find out where my camera was, I finally got an answer back, they said I needed a new shutter which will cost $300, They said I should just by a new body for $400. What Nikon does is set that error message to pop up at about 35000 shutter releases, and you can't do a thing about it, once they hooked my camera up to thier system the said I had over 36000 shutter releases, where the average person takes 10000 a year and they want you to replace the body every 3 years....so before buying any camera, always check out how many shutter releases you can get when you buy a camera
Rob Smith
Victoria, BC
