The unit turns on OK, and works for a while, but will suddenly switch inputs, or go to a locked up state where all the lights are on at once (all inputs lit up). Vibration, like tapping on the case, aggravates this behavior.
For mine, the source of the issue was a loose screw at the rear left corner of the main board of the unit (the one with the output transistors). The solution was simply tightening that screw (which also carries a main ground wire).
Really? What tool did you use?
