20 Most Recent Dual XDVD8181 Car Video Player Questions & Answers
5answers
How do i by pass the parking brake no video
1. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
2. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
From here:
http://forum.ecoustics.com/bbs/messages/4/302701.html
6/22/2018 10:04:53 PM • Dual XDVD8181... • Answered on Jun 22, 2018
2answers
WHAT IS THE PROBLEM WHEN A NO SIGNAL SIGN COMES UP
Well first off , what are you powering the dual from...is it "switched" power and fused? Secondly, what media are you using? A store-bought DVD or your own from a PC?
answer these and I'll help out
11/24/2015 4:04:14 PM • Dual XDVD8181... • Answered on Nov 24, 2015
DUAL XDVD8181 car unit - motorized TFT screen won't come out!
Open it again and check the ribbon cable for cracks, the one that get drag in and out every time it open and close. Because it is a defect for Pioneer too, and Pioneer would replace it free. Goodluck.
6/17/2015 12:07:49 PM • Dual XDVD8181... • Answered on Jun 17, 2015
7answers
How do i bypass the parking brake switch in order for my video to play
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press ENTER
3. DVD METHOD (Permanent)
** Insert a DVD
** Enter 26604
** Press ENTER
Credit: Adam P.
4/23/2014 7:57:14 AM • Dual XDVD8181... • Answered on Apr 23, 2014
3answers
MY DUAL IN-DASH DVD WON'T LOAD ANY DVD OR CD.
OK so be said the player will not load the CD...how in the world is he going 2 clean the lens if the player won't load anything? I'm just sayin...
1/1/2014 1:23:53 AM • Dual XDVD8181... • Answered on Jan 01, 2014
Video bypass for dual xdvd700 without remote
i used a switch, to the ground, and i'm still having problems, so yeah lol
2/10/2013 11:42:46 PM • Dual XDVD8181... • Answered on Feb 10, 2013
4answers
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
1/28/2013 3:48:22 PM • Dual XDVD8181... • Answered on Jan 28, 2013
My dual xdvd8181 head unit will not power on. i bought it used and tried the old power wires to positive side of battery and ground to negative side and nothing happens. the in line fuse on the power
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio. The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
1/7/2013 6:45:01 AM • Dual XDVD8181... • Answered on Jan 07, 2013
Se descompuso el mecanismo del
amigo solo presiona el boton de mute y power por 15 segundo, ambas al mismo tiempo y automaticamente te pedira un codigo de seguridad el cual es 122164 y listo el equipo arrancara normalmente.
5/29/2012 4:45:56 PM • Dual XDVD8181... • Answered on May 29, 2012
2answers
Dual xdvd710
check on the main wiring harness you wil see a black box on the yellow wire. open up the cover. there is a 10 amp mini fuse inside. if it is blown replace the fuse. also check your main radio and accesssory fuses in your fuse box. if no fuses are blown check all wiring connections.
5/3/2012 10:42:19 PM • Dual XDVD8181... • Answered on May 03, 2012
4answers
Volume control problem
Ok my head unit is stuck on 10 with my valume and it wont change how can I fix that
2/22/2012 5:30:22 AM • Dual XDVD8181... • Answered on Feb 22, 2012
2answers
Not reading cds
my forj ent is not reaqding my dvd
1/14/2012 5:51:33 PM • Dual XDVD8181... • Answered on Jan 14, 2012
My dual cd/dvd will only blink red on the volume control knob, how do i fix that?
check the fuse also the ground
12/14/2011 6:42:27 PM • Dual XDVD8181... • Answered on Dec 14, 2011
5answers
Xdvd710 in dash dvd player (dual)
just ground the yellow blue wire
12/5/2011 10:07:03 PM • Dual XDVD8181... • Answered on Dec 05, 2011
My dual xdvd710 was working
your dual xdvd710 is having a power problem. The power board is defective that's why the dual xdvd710 is not powering on. One way or the other, the power board has been affected.
A component on the power board like capacitor may have been defective.
Detach the dual xdvd710 from the truck, get a screw driver, disassemble the dual xdvd710. Use a meter to read the power board of the dual xdvd710, in other to detect the bad component. Make necessary replacement and the dual xdvd710 should power on again.
Purchase the replacement online or at any electronics accessories store within your vicinity.
Good luck.
10/22/2011 4:45:07 PM • Dual XDVD8181... • Answered on Oct 22, 2011
I want to download music
it should be mp4
9/21/2011 8:36:37 PM • Dual XDVD8181... • Answered on Sep 21, 2011
I've read thread after thread
You can buy the remote here:
Dual remote
The code however, will have to come from Dual, and you will probably need some proof of legal ownership since this is a security feature to prevent thieves from benefiting from their crime.
8/31/2011 12:11:45 AM • Dual XDVD8181... • Answered on Aug 31, 2011
Just hooked up dual xdvd710
it sounds like a wiring problem i have seen these in many in dash dvd players. if you still have the manual just check your connections and your grounds there may be a short or mis matched wire
5/14/2011 4:14:58 AM • Dual XDVD8181... • Answered on May 14, 2011
Dual XDVD8181 Car Video Player Logo
262 questions posted
Top Dual Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dual Car Audio & Video
Most Popular Question
se descompuso el mecanismo del
  • Car Audio & Video
