SOURCE: My VGN FS920 shuts down at the window loading screen
ok no need to get a bcakup disk or downlaod anything
if ur hard drive is original factory fitted
and
ur laptop came with pre loaded OS as XP
then do this without disk
Sony: When you first turn on the laptop and see the VAIO logo screen, press the F10 key (you need to do this before the VAIO logo disappears).
pls let me know and rate me FIXYA for help
SOURCE: how do I connect my sony vaio vgn-fs920 to a tv?
I found this web site with step by step instructions on connecting to a TV. I haven't tried it yet but it may be helpful to you. http://www.labnol.org/software/tutorials/how-to-connect-laptop-computer-tv-screen-lcd-hdtv/2331/
SOURCE: i have a sony vaio laptop model vgn fs920. when i
What are the error messages/codes? You can get some information from sony's knowledge based system in esupport.sony.com. Just click on FAQ solutions. It will ask you to type the model number of your unit. On the next page, on the right side, you will see
, type the error codes/messages you get then it will tell you what might be causing the issue
hope this helps..
SOURCE: Sony VAIO VGN-Z550N/B 13.1" Laptop how do I
If you are still having the original hard disk holding alt + F10 at boot will start the factory restore process
SOURCE: Old Sony Vaio PCG ???
Rerun you XP set up and try doing a upgrade instead of a install this will allow you to maintain your data and also put the new drivers for *********** board into the BIOS
