SOURCE: Powers off by itself.
Has anyone gotten a resolution for this the only answer I saw was the SSB Board. Is there a cheap place to get parts. Philips model 50P8341 goes off by itself also wont come back on if you unplug it for a while it will come back on.
SOURCE: Power on projection tv will not stay on, Pioneer SD-P4565 projection tv
What model tv do you have?
SOURCE: TOSHIBA dlp projection, model 42hm66 won't stay on
Could be the power supply. You can check the power from supply with multi-tester or voltmeter. If have a service manual, then I suggest testing the ballast as well
SOURCE: TV stays on for few mins and then turns off
IF its the lamp for Lcd. Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is xl-2200 found it here: http://www.discount-merchant.com/SearchResults.asp?Search=XL2200+?Click=48173 God bless you!
SOURCE: turns on stays on for about 5-10 min then shuts
For starters..you have two bad electrolytic capacitors. If you change them now you may be able to save this TV from a bigger problem. Like a new flyback and a retrace cap. If you can..look inside the back cover and look for two bulging caps. I'm telling you what I've heard other TV techs discuss.
