20 Most Recent Toshiba 52HM95 52" HDTV Projection Television Questions & Answers
3answers
Toshiba 52HM95 whirring noise
Color wheel. Not replacable on this set. Removing light engine and having rebuilt is only solution. Part no longer available.
8/3/2017 12:17:24 PM • Toshiba 52HM95... • Answered on Aug 03, 2017
Loud buzzing sound
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/29/2017 4:59:23 AM • Toshiba 52HM95... • Answered on Jul 29, 2017
Where is reset button?
http://www.manualslib.com/manual/781175/Toshiba-52hm95.html
6/5/2016 5:09:04 AM • Toshiba 52HM95... • Answered on Jun 05, 2016
0answers
2answers
Toshiba model 62HM95 DLP. There is a fan noise
it is just a noisy fan.
yes you can order from tosh and if you are able it is an easy fit. Just make sure you unplug the tv from the mains
12/10/2014 2:15:43 PM • Toshiba 52HM95... • Answered on Dec 10, 2014
NO SOUND
To help people who want to help perhaps you could give more detail. 1. Did it ever produce sound, has it suddenly stopped working 2. Have you tried different inputs for example a blu ray or DVD payer or games console 3.have you disturbed the cabling or changed settings? 4. have you tried looking at the audio menu to check nothing has been changed? 5. Have you tried headphones 6. Have you tried feeding the audio to something external? 7. What were the circumstances leading to the fault?
5/13/2014 5:12:08 AM • Toshiba 52HM95... • Answered on May 13, 2014
Color
change the video board if it's dlp projection
4/25/2014 7:06:14 PM • Toshiba 52HM95... • Answered on Apr 25, 2014
Tv stuck on record
check your record settings in menu . put them all back or click on reset.
2/26/2014 8:24:44 AM • Toshiba 52HM95... • Answered on Feb 26, 2014
My toshiba 52hm95 i still without a picture replaced the lamp and the ballast,the color wheel spins(cut the knob with the plastic tip attached from the lamp access door to get it to power up while fir
did you change the bulb or the bulb with housing. 2.5 volt is start up volts. this is to check if the bulb is there or not. check that you have the bulb connected good you can test the bulb with a meter. on rear occations the bulb may not work even a new one.
2/26/2014 8:18:55 AM • Toshiba 52HM95... • Answered on Feb 26, 2014
Problem with color. no reds or greens
035382f2-36ab-4576-b96d-eb9bbc132b2e.jpg Check this part. if the wheel stops moving you will only get one colour its stopped on. dust can stop the wheel moving or the motor could of failed.
2/26/2014 8:13:57 AM • Toshiba 52HM95... • Answered on Feb 26, 2014
Toshiba 52HM95 52" HDTV Projection Television Logo
234 questions posted
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 52hm95 lamp breaks after only
  • Televison & Video
