20 Most Recent
RCA P52937 52" Rear Projection Television Questions & Answers
No picture but has sound and can change channels
Check the lamp and its inverter. If lamp has failed, replace it along with it ballast [inverter]. It is the best practice.
If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
Lamp replacement procedure to many brand projection TVs are given with illustrations. Never forget to reset the lamp time after replacement.
I have sound but no picture.....
sound like the high voltage is dead and needs repair.This unit has three projection bulbs and one HV transformer.The HV transformer is common to all three CTRs
Fadeing of picture RCA P52937
Sounds like it could be your bulb going bad I would check some places like rivervalleyelectronics.net or hdtvpartstore.com and see if they have your bulb is in stock it may not be to cheap but i beats buying a TV. I would direct you to the manufacturer but they probably have stopped supporting this type of tv.
RCA Big Screen is fuzzy.
Common problem and RCA recommends the following to cure: replace R17520 with p/n# 218508, C11503 with p/n# 194903, and crystal.
Bill
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Ptk195m4b
If the issue is convergence off I can tell you what part/s are most commonly bad.
