SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
SOURCE: Thermador Built-in Oven Model SMW272
usually this is because you have the connecter on the touch pad off by a pin or not seated well. sometimes all it takes is taking the front touch panel off, re seating the connectors, and putting it back together. these thermadores are very sensitive to it for some reason. if all else fails, take all of the small multi pin wire connectors off one by one and re seat them. it should take care of the problem if it wasnt there before you started. good luck!
SOURCE: thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
SOURCE: we had a power outage and when the electricity was
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
SOURCE: Thermador Model C302 Convection Oven
Hi alatfios,
This error F24 and the beeping sound is unfortunately because of a bad touchpad. The error code F24 means that the key has been stuck for longer than 120 seconds. The beeping sound that you are getting means hte button is opening and closing. Heat will cause buttons to stick sometimes. When you warm your oven up it expands the buttons and makes it so a button is being held down so you can't push any more to turn it back on. The touchpad is the glass assembly on the front. You can purchase it online and that is the only part you need. Kindly click here to purchase.
Hope it helps.
Thank you for using Fixya.
