I was sewing a quilt block using a straight stitch. When I tried turning the wheel by hand to raise and lower the needle it was very stiff to turn. My machine was just serviced a few months ago and I have oiled it since then but thought maybe it just needed oiling again. Oiled everything and was running it without any fabric or needle to work the oil into the mechanisms and the feed dogs quit moving. Without feed dogs moving it won't feed the fabric through to sew.
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
SOURCE: The stitches are fine; the
I am sure that you have tried adjusting the presser foot pressure. But if not, you might try adjusting the pressure.
SOURCE: Hi, I bought my Pfaff
Take it to the shop, especially if still under warranty. Sounds like the feed dogs have moved out of position.
SOURCE: I have oiled & cleaned
If you have checked all the basic things you may need to have the mahine retimed
