Netopia 2241N-006 Ethernet/USB DSL Modem ADSL Logo
A
Anonymous Posted on Oct 05, 2012
Netopia 2241 modem red light
The internet light on the modem is red and I cannot get an internet connection on my personal network.
1 Related Answer
Anonymous
  • 94 Answers
  • Posted on May 29, 2009
SOURCE: constant d/c
Do you have call waiting and is it turned off? If not turn it off, please.
I need to find a driver/sortware program to get my netopia 3D reach wireless adapter up and running. all i can find are these driver scans that want me to install them and scan my computer to tell me I...
Here's a driver-free, software-free solution.
Turn your cable-modem (or DSL-modem) off.
Turn your Netopia off.
Connect:
Ethernet--port on cable-modem <-- cable --> WAN port on Netopia.
One LAN port on Netopia <-- cable --> network-port on your computer.
Turn the cable-modem on, and wait until its lamps settle-down to a repeating pattern.
Turn the Netopia open, and wait until its lamps settle-down to a repeating pattern.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you see)
Login to the web-server running "inside" the Netopia.
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID of your choice.
Select the 'WPA' level of encryption.
Enter a network-password of your choice.
Click OK
Restart the router (if it did not automatically restart).
Disconnect the Ethernet cable from your computer's network-port.
Click "View Available Wireless Networks".
Click the SSID of your new network.
Click Connect.
Enter the password, when prompted.
Voila! You have a wireless connection to the internet.
Newly reinstalled windows is not recognizing my 2241 Netopia driver via ethernet cable. I believe i just need the driver / software that will allow windows to recognize that i have a modem connected
You can do it manually without the CD.
MAke sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the router
ad the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
2answers
I have a netopia wireless router, I've just had comcast install the internet however I would like to install the router. the modem to my computer accommodate only one ehternet cable at a time and it...
You can connect your computer to Internet if you have a Wi-Fi card in the computer. You need to connect the modem ethernet cable to the netopia wireless router and then connect to internet through wireless connection. First task is to configure wireless network connectivity on your netopia router connecting the 1st ethernet port to your pc lan card port, you will need the netopia instruction manual for this. The wireless configuration will be through a browser window(like internet explorer/mozilla firefox). This may take roughly 20 -30 minutes.
1helpful
2answers
How can i connect my laptop to internet without router device via desktop pc connected to internet
you could its called an ad-hoc connection..but youneed either a wireless adapter on your desktop or a network hub
WHAT ARE THE STEPS TO HOOKING UP MY WIRELESS ROUTER TO MY NETOPIA ROUTER - RIGHT NOW NETOPIA IS BEING FED BY MY CABLE MODEM
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Self-assigned IP address and may not be able to connect to the Internet
if its a wireless network it assigns yyou an ip immediately solong as you are not connecting directly so dont bother about the ip just connect and see what happens.
1helpful
Internet light is red
If you haven't done so already I would turn the netopia router off and back on again at least once. If that doesn't solve the problem it's probably a sync issue with your providers equipment. I'm assuming you're using ATT because of the Netopia router, but generally speaking you should contact your provider and have them run a line test.
They can determine if the line is good or not. If It is all working fine at the time you call ask them to run monitoring on the line for the following 24-48 hours to try and anticipate a reoccurrence. Insist that they call you back regardless at the end of the monitoring term to share their results with you.
Hope this helps.
MO
Hope this helps.
Speedstream 5360 modem
  1. From the System area, , select Network Settings.
  2. Select Edit Settings.
  3. Select Additional Settings, and then select PPPoE Settings.
    1. Enter the PPPoE information provided by .........on the screens for: .......
    2. User Name ......
    • Password
    • Service Name
    1. Select Done. When prompted, select Test Xbox Live Connection.
    Netopia 2241 Modem losing sync?
    If your modem is losing sync with ADSL 2 that means that your line has a problem. Try having your DSL provider move you to a new Cable and pair.
    Top Netopia Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
