20 Most Recent Netopia Cayman 3347W-Ent Wireless Router Questions & Answers
Wireless routers don't need drivers. Maybe your wireless adapter needs drivers.
Netopia Cayman... | Answered on Oct 15, 2013
Explaining an opinion on DSL's speed doesnt help fix a problem. Not to mention the fact that DSL is on a digital subsciber line, your own phone number, not the neighbors, you have it backwards, its cable that can have its speed impaired if all your neighbors go on.
Anyway, I am an expert with netopias. I trouble shoot them all day long on people's DSL connections. The symtopms that MacWyb is describing sounds like he has degregation of service that needs to be fixed by maintenance. They can do whats called a rip and rebuild, where they take off the virtual circuit and virtual path (vp and vc) and then build it right back, this clears this type of problem up quite often. It would also be a loose wire at the D-mark, the gray box on the side of your house, thats happened to me twice now. Or, It could be you're on a redback that has too many customers assigned to it, maintenance, if this is the case, would have to move your circuit, assign it to antoher redback, or brass router, whatever they're on.
In anycase, It means a call in to technical support with your ISP. They will create a trouble ticket to look at it for you.
This is all taking for granted you dont have a buzz on your phone (which would make it a telco issue, a call to your local phone company to fix the line), and that you have all your DSL filters installed on every phone in the house, including fax machines, etc.
spin
Netopia Cayman... | Answered on Oct 12, 2013
You reset the router. that means router is set on factory default.settings has been changed now that's why connection manager is not responding properly. Now you have the run setup CD and set the router again.
Netopia Cayman... | Answered on Oct 11, 2012
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. Toconnect to your wireless router from the computer/laptop, configure thewireless card in your computer/laptop with the router's wireless settings ieSSID, plus the WPA or WPA2 encryption key. Then computer/laptops cancommunicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
Netopia Cayman... | Answered on Feb 27, 2012
You need to set up port forwarding for the ports you're planing on using.
Netopia Cayman... | Answered on Aug 08, 2011
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Netopia Cayman... | Answered on Jun 18, 2011
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Netopia Cayman... | Answered on Jan 17, 2011
I searched the user manual, and it does not specify. Try leavng it blank or try Admin.
If it was bought used, it may have old old info in it preventing your access.
Use the recessed reset button next to the power input to restore to factory settings. Hold for about 10 seconds then power off then on.
Netopia Cayman... | Answered on Dec 03, 2010
Sounds like a firewall issue on the computer that you are trying to RDP/VPN from, or possibly that these services have not been allowed through the routers firewall.
Log on to the routers web configuration page, and see if there is the option to allow these services through.
Netopia Cayman... | Answered on Oct 17, 2010
Turn the router off, unplug it completely for 10 - 15 mins, then replug and turn on. If the problem is still present, press the reset button (small small hole, may require a needle) for 5 - 10 seconds if needed then follow the first step.
Netopia Cayman... | Answered on Mar 31, 2010
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Netopia Cayman... | Answered on Mar 28, 2010
What is the operating system on the computrer ?
If it is Windows XP Sp1 then it will not support the WPA.
You can change the security to WEP.
Or you can update the Operating system to XP- SP2
Make sure that you are using the correct password while connecting to the network
Click Here to know more about routers
Netopia Cayman... | Answered on Nov 20, 2009
That wont help either!!!!!!
What you can try is .....try once more to update firmware in case you still get that same message.Please get in touch with technical support of Netopia ask them to update your firmware
Hope this will resolve your issue
Netopia Cayman... | Answered on Nov 02, 2009
the cable modem should be giving the netopia an ip address
go inside the netopia by opening Internet Explorer and type 192.168.1.254
a little window will pop open
the username is admin, the password is the serial number on the bottom of the netopia
once in, click on configure, lan, then wireless at the bottom
make sure the wireless box is checked
name your network (SSID its called) like randy578
then click advanced if you want to enable wireless security encryption, your key to get online securely
click submit underneath it
clike the yellow triangle up at the top right
click save and restart
in like 2-3 minutes, click the wireless connection icon by your clock
connect to randy578 network
you should now be online
spin
Netopia Cayman... | Answered on May 01, 2009
in the ATT region, they use PPPoE (in general, even if you have sticky static IPs)
plug in the router, turn it on, open Internet Explorer and type 192.168.1.254
click on configure, then click on quickstart
type in your username (the emaill address from ATT like lc61544@att.net) and your password for your email address
in like 2-3 minutes, you can open IE or firefox, whatever
and see if you're online (you should be)
spin
If you got the netopia in anyone of the 13 states that ATT controls, then that netopia will work in any other state, not just the phone number it was attached to. We are implementing technology now that it will be phone specific, but most people dont have that installed yet.
All you have to do is reset the netopia, open a browser, type 192.168.1.254 and set it up with the new username and password you created when you got your new DSL service.
spin
you can make the lan ips what ever you want them to be. The way you get thru firewalls, which on the router is NAT, is to set up mapping from your WAN ip to the LAN one you creat.
if you are saying instead, that you put the netopia in bridgemode, and are passing all the ips thru the router to the Check Point firewall you have set up behind it, then you need to configure your firewall correctly.
spin
Try this and see if it works for you. Telnet into the modem. Hyperterminal will work fine for this.
Type config, then hit the enter key.
Type set, then hit the enter key.
At this point look at your monitor. Does the bottom line look like this?:
autoConfig (on) [ off | on ]:
If so, type off. Then hold the enter key down for several seconds untill you get to lines that look like this:
Netopia-3000/xxxxxxxx (top)>>
Then type save and hit the enter key.
When the screen says that the configuration data has been saved, type exit and hit the enter key. Then type restart and hit the enter key. When the modem restarts close hyperterminal and access the Netopia using your web browser.
Netopia Cayman... | Answered on Apr 19, 2009
With each new router comes a new WEP KEY by default this could be found normally on the back of the router/access point near the bar code it should have something like this:
SSID: XXXXXXXX WEP KEY: XXXXXXX
If you don't find this sticker or don't have it just reset the router or connect by cable go to the web interface and copy or change the WEP Key there defined.
Hope that helps.
If you need and advice about a new wi-fi router....linksys all the way...;)
Netopia Cayman... | Answered on Feb 28, 2009
on the back panel you will find reset button. press and hold for 20sec. So your router will get back defaul settings.
Netopia Cayman... | Answered on Feb 11, 2009
Netopia Cayman 3347W-Ent Wireless Router Logo
34 questions posted
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Netopia Computers & Internet
Most Popular Question
could walk me thru
  • Computers & Internet
