110v 220v exchange power transformer
Sorry if it's obvious but just confirming that you are able to covert the 110v system to a 220v system with no hassles ??
An stepdown transformer is needed should you buy in US and use it Europe
However, if your on a technical side , trace the primary windings , and check
There are European versions which are already 220V, no need to convert.
Source : page EN 99 of the
Onkyo TX NR616
manual
Rommel,
Thanks for your reaction.
A transformeris the obvious way out, but was wondering if I could set the 220V power supply of my old Onkyo into this new one. Or if it is possible to order a 220v supply for the tx-nr616 as if it was broked and neede replacement.?
The reason I want to buy it in the US, is because it is twice more expensive in Europe.
Hans
if you are only here in our country , it would not take about 2 hours to rebuilt it, and convert to 220V
you mentioned broke? is is totally shorted? have you tried running it alone?
i will look for replacement on line :)
here is a link , which of the two (2) transformer are you referring to small or big?
http://www.google.com/imgres?imgurl=http...
look closely if it is just open and not shorted , could be thermal fuse , i can see it from the image
looking closely also indicates it is good only for 110V
with a multimeter check resistance of the white and violet wire , if there is a resistance near or about two (2) ohms, it might probably be OK, unless fuse breaks when turn On
test also the two terminals of the primary windings with a multimeter. If it is good then the small transformer ( standby ) is the problem
SOURCE: Onkyo TX-SR804 power supply
If you imply an AC voltage transformer by saying "power supply", I don't believe it will be difficult to find one. If you stay in Istanbul, I recommend that you go to "Dogubank". You can choose from a wide variety of options at that place. All you have to pay attention is that the AC frequency (Hz) of the transformer you're about to purchase. It must be around 50Hz to operate your amp.
