20 Most Recent
Onkyo TX-SR501 Receiver Questions & Answers
Onkyo receiver with no sound
There should be 3 clicking sounds coming from the amp. You amp miss the last clicking sound coming from the speakers ,spk, output terminals. There should be 3 relays on the spk output board. Their 12 contact points may have a layer of black colour oxide. Remove the oxide can fix the problem, perhaps.
1. Unplug the amp.
2. Open the cover
3. At the spk terminal, there is a horizontal board.
4. Look for the 3 relays and take them out.
5. Open the relays and remove the oxide layer by a sandpaper.
6. You need an iron solder, a desoldering pump and solder.
7. If does not help, check for the 24V for the 5 relays. 2 is for B+ and B-.
TR SR706 purchased 6 months ago. Unit powers on to
Onkyo USA Corporation18 Park Way
Upper Saddle River, New Jersey 07458
For Dealer, Service, Order and all other Business Inquiries:Tel: 201-785-2600
Fax: 201-785-2650
Hours:M-F 9am-5pm ET
For Product Support Team Only:1-800-229-1687
Hours:M-F 9am-8pm | Sat-Sun 10am-4pm ET
Regional Service Center
Dtr Technologies2525 West 6th Aven
Denver, CO 80204
303-573-6288 (Tel)
Distance: 960.0 miles
show map
Please see below for local Service Centers.
Media Associates Inc.612 National Ave.
Mountianview, CA 94043
650-968-2444 (Tel)
Distance: 33.6 miles
show map
http://www.onkyousa.com/loc_results.cfm
I try to connect a
The nature of whatever is on the upstream side of a digital signal is invisible to the device at the other end of the cable. Bits is bits, as we say. The undefined 'satelite to optical audio' device is probably at fault or not set right. PLUS, on theOnkyo you have to assign digital inputs. Read the manuals.
I don't have the manual
Use a search engine for "Onkyo TX-SR501 manual"??
Hint: retrevo has it.
You might also hunt for the TV manual as IT is a player in the scenario, too.
I have a bose speaker
What model Bose? If the speaker wires have molded ends they are possibly NOT electrically compatible with anything but the electronics they were sold with.
