SOURCE: Acer Crystal eye Webcam Settings?
go to your device manager to see if your webcam is properly installed. if installed open webcam from my computer click webcam and click the settings you wanted.
SOURCE: Acer Crystal Eye Webcam - "Camera Not Found" or "Camera Busy"
ok what u might have to do is uninstall the camera and remove it...reboot ur pc with the camera not plugged in or is it an internal camera....please email me at [email protected]
ill try to help u out as much as i can..
tc for now
mark
SOURCE: acer aspire 6930G crystal eye webcam no camera found
Hi
The problem is with Camera driver.
Please uninstall the driver from Add/Remove Programmes and reinstall from media given by manufacture or download the latest driver from manufacture web site.
Hope it will work fine.
SOURCE: Acer Aspire One AOD250 Netbook Built-in Webcam problems....
try this it sometimes works. 1. Start Registry Editor (Regedit.exe). START > RUN > (Type) REGEDIT (and hit ENTER) 2. Locate the UpperFilters and LowerFilters value under the following key in the registry HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6BDD1FC6-810F-11D0-BEC708002BE2092F} Write down the upper & lower filter valuse. Delete the UpperFilters and LowerFilters value (it's safe, and if could be restored later on if you have written it down, so don't worry)
SOURCE: crystal eye webcam for acer aspire 6920G says camera not found
hey, I had the same problem, I've got an Acer Aspire 6920 and I swapped out Vista that was on it for Windows XP
I went to the link you posted but it just goes to acer.com
so I figured I'd try something
if you go to acer aspire 6920 drivers, you can only pick Vista and Windows 7, and not Windows XP
instead, pick 6530 drivers (older acer) and pick the Bison driver:
http://global-download.acer.com/GDFiles/Driver/Camera/CCD_Suyin_2.0.8.3.zip?acerid=633639858186446758&Step1=Notebook&Step2=Aspire&Step3=Aspire%206530&OS=V10&LC=en&BC=Acer&SC=PA_7
Install it (with or without installing the previous Crystal eye, doesn't matter, and it will work properly
