With you concern about this printer what we need to do here is to download the printer software/driver to completely install the printer to your computer to correct your problem with it.
You can go to this link and then download the software/driver , just click HERE and select the operating system of your computer and then continue with the download and once done run the software and follow the wizard.
James, to download the software click HERE On the page you will need to download and install the driver for your printer. Download the file to your computer, click on it and install it. Then reboot the computer and all will work fine.
You will also find other software to manipulate photos,etc., which is optional for you to download. As well you will find on the bottom of the page, your user manual for your printer. Download the manual if you have any other questions pertaining to usage of the printer or optional software. I hope this helps and good luck!
Your best bet is to visit the CANON Support Page They've got the latest drivers and software for all their printers online. You can download a fresh copy...no password needed.
make sure you installed the software properly..sometimes some software requires you connect the printer first then install software...other times you install software first then install printer....make sure the settings are set up the same on the printer and computer....make sure all connections are secure..check owners manual...
Go to the HP website. Click on the upport link. Lookup your specific printer model # and operating system you are using. Download the appropriate files and install. You should be all set. Hope this helps & please take a moment to rate this solution. Thanks.
First, disconnected the printer from the computer and turn it off.
if you have the CD that came with the pirnter, install the software from the CD.
if not go to the link and download the driver and software http://downloads.lexmark.com/perl/downloads/downloads.cgi
restart the computer, turn on the printer and connect the printer to the computer.
You need to download the software for Vista in order for you to mae the printer work on the vista computer, Just go to this link and download the software for vista of this printer , Just check this option there "I have read and understand the information above, and wish to download the designated software" then proceeed with the download...
