The subject is pretty self explanitory. The picture extends beyond the screen and I end up not being able to see the top, left, right, and bottom part of whatever im watching. This is perticularly annoying when watching movies which require subtitles... If anyone knows a way to fix it, Id be grateful for a solution. Also, Ive tried messing with every setting there is in the menu but nothing works.
My tv has same problem I opened it up but it only has horizontal adjustment and no vertical
There should be a vertical height adjustment control potentiometer near the vertical output IC on the right side of the PC board near the front section of the TV that can be adjusted to shrink the picture vertically. Be careful not to short anything out or getting yourself shocked in the process if you decide to try to adjust it yourself. Good luck. This chassis has also been known to have bad solder connections in that area also, so don't man-handle the printed circuit board roughly.
Oh, btw, the model number in the title is incorrect..i didnt notice that before...its a a32b41w. Hope that helps
Yeah, I've got the same problem, but it IS with the D32F51, but my specifics might be a little different.
I am sending an HD-RGB signal to the TV and I am stuck with one of two errors. One, I send the display area @ 800x600 and the TV doesnt' register the signal. OR two, I send it at a higher size and then the display area extends beyong the screen so that I don't see the full desktop.
