20 Most Recent
Zenith D32D51 32" TV Questions & Answers
Screen Size is Too Big
There should be a vertical height adjustment control potentiometer near the vertical output IC on the right side of the PC board near the front section of the TV that can be adjusted to shrink the picture vertically. Be careful not to short anything out or getting yourself shocked in the process if you decide to try to adjust it yourself. Good luck. This chassis has also been known to have bad solder connections in that area also, so don't man-handle the printed circuit board roughly.
I am connecting my laptop to my Zenith TV with a
Hi, your laptop should have a key that has a picture of a monitor on it, that key activates the function of external display... first you need to find that key which probably would either be one of the F# keys or one of the numeric keys, you can use that function by holding the F or Fn key down while pressing that key, for every click you will switch the function between three modes internal display only, internal plus external or external only... just be sure to switch back so you do not get stuck on a black screen... good luck
When I plug in my 36" Zenith TV the screen stays
Caution: Never power on the TV set again until this fault is retified.
It is anode arcing takes place inside the TV. Its final anod cap is arcing with neighboring surroundings. A smoke like fume along with a foulin smell will be there. It is repairable. Its Line Output Transformer [LOT] shoud be replaced with similar type and number. Before connecting the anode cap to the final anode of the picture tube, cleen the anode hole and surrounding area with some sort of cleaning solvent [we uses pure turpentine for that purpose], throughly, and wipe it out to dry out well.
Color tint went out
replace the color ic have tech do that. checks should be made around the same ic for transistor leakage
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
