Kenmore 46462 Front Load Washer Logo
Anonymous Posted on Dec 22, 2008
Kenmore Elite HE 3t suddenly stopped spinning and draining
Washer suddenly stopped spinning and draining at the end of washing cycle. I followed the trouble shooting suggestions per manual but without success. Any suggestion to deal with this problem.
Thank you.
SK
  • Anonymous Jan 06, 2009
    my repair man said we needed a new motor ($207) and a new drain pump ($142). He ordered the parts Dec 15th and they still haven't come in!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
304
Points
Cleaning pump filter.
Cycle will not spin and drain properly near end of cycle. Keep getting F11 fail codes when I try resetting my kenmore elite HE 3t any suggestions?
Hi Shaun, I just found (and watched!) a good youtube video which may help with your problem regarding the F11 code, link follows below.
Trust this helps, best regards Alan
Troubleshooting and Repairing the F11 Error Code in Whirlpool Duet Washer
Kenmore elite washer
hi
unfortunately the programmer is faulty
1helpful
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
Kenmore elite washer sm 9711034, washer will not go through spin cycle at end of wash cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
1helpful
2answers
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Kenmore Elite HE 3t washer - stops and flashes error code F 02
"F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. The washer will NOT complete a cycle with the condition present that is causing the error code. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Alexander
vince
