Water pressure suddenly decreased but when the sprayer is removed it is fine. There seems to be something slowing the pressure down in the sprayer handle but i can't see how to take it apart
SOURCE: Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
SOURCE: Low Water Pressure in Kitchen Faucet
Ihad the same problem. It is not the screen. What you need to do is get a spray diverter the old one disintergated and is blocking the flow. You have to take the collar off and underneath is the diverter. This is after you take the ball and rings out.
SOURCE: Kohler side sprayer. When in use both it and main
sounds like sticky diverter should replace it
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
SOURCE: I have a Grohe Ladylux plus kitchen faucet very
When you remove the screw, you will have to give the handle a slight pull to take it out. Sometimes it is stuck after being used too long.
