One side has brass screw and silver screw. other side has two bronze screws. are the brass and silver the hot and neutral in? this controls only one fixture - do I just put the hot to the fixture on one of the bronze and ignore the other?
SOURCE: I have just installed 2 Leviton decora switch with
This is a single pole light switch and should be wired as any other SP switch. The only difference is that is has a pilot light. All the white neutral wires are tied together and then pushed back in the box with none connected to the switch. The grounds are tied together with a jumper wire connected to the green screw on the switch. That will leave you with 2 or more black wires. If you have just two normally you can connect them to the two screws on the switch and it does not matter which screws. However it may be that with the pilot light you need to connect the wire going to the light to the top screw and the power wire to the bottom or vice versa. Try both ways. If you have more than 2 black wires you need to connect the incoming power black wire and outgoing power black wires together and then jump to one of the screws on the switch. The black wire left over is the black wire going to the light itself. If none of this works then it is obvious the pilot light in the switch is burnt out.
Testimonial: "Thanks a million. I will recheck the wiring tomorrow. Chas"
SOURCE: I have a Leviton 5225/702 from Home Depot Canada.
For what you want to do, the side of the device that has the two brass screws tied together with a metal break off tab is _not_ used, and do not break off the tab ("tie") On the other side of the device, connect the white (neutral) wire to the silver screw and the black hot wire to the brass screw that is just above the silver screw on that same side.
SOURCE: I have a leviton combination (2) switch... I want
Don't break away the tab.
It sounds like you have Hot wire connected to wrong side of device.
Electricians don't guess, they test.
Separate wires. Turn power ON.
Test each wire to bare ground.
Tester lights up on Hot wire.
Hot connects to brass screw(s). This will feed power into each switch.
Wires going to Load (lights) connect to each silver screw.
