20 Most Recent
Leviton Decora Combination Switch - 5625-I - Ivory Questions & Answers
I have three wires, two
Connect the white on the switch to the white in your house, one black to the hot coming in, and the other black to the hot wire to the overhead fixture.
Insatllation
You have switch-plug combo.
1) Screws are color-coded.
Dark screws, brass screw, silver screw.
2) Electricians don't guess, they test
-Separate
wires for testing. Do not untwist any wires that are twisted together.
Note which wires were connected on same screw on previous device.
-Tape tester leads to wood sticks to keep hands away from power
-Turn power ON
-Test each wire to bare ground wire.
-Tester lights up on Hot wire. Hot connects to dark screw.
-Hot is identified.
-Test Hot to all other wires, except bare ground.
-Tester lights up on Neutral. Neutral connects to silver screw.
-Final wire goes to Load (light, fan, motor). This wire connects to brass screw.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
I have an outlet that
Electrical devices have color-coded screws.
Electricians don't guess, they test.
You have tested the wires.
1) Combo switch-outlet device screws are dark - brass - silver - green
Hot to dark
Neutral to silver
Load wire (wire that goes to light, fan, motor) to brass
Bare ground to green screw
2) If you want switch to control the outlet on the combo device.
-Device must have 2 dark screws
-Look at dark screws, there is a break-away fin that connects dark screws.
-Remove break-away fin.
--Now there is one dark screw for the switch part of device, and one dark screw for outlet part.
-Connect Hot to dark-for-switch.
-Run jumper wire from brass screw to dark-for-outlet.
-Neutral to silver
-Switch on combo device will operate outlet on combo device
For a price, expert speaks with you over phone while you work on wiring or any do-it-yourself project.
Wiring a leviton 5625-W switch receptacle combination
You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
I cannot turn off light that uses a Leviton Cat /no 16400, DHC switch not can i find the receiver box that controls the lights
A Leviton DHC receiver device can look like any other switch or receptacle so if you didn't install it or not provided a map then you'll need to locate it.
Likely the wall switch that originally controlled the light was replaced with DHC device and paired with the 16400 at another location. If you can't identify it, then removing face plates and devices may be the only practical method to locate it.
If your not comfortable with removing devices safely, hire an electrician.
https://www.mc-mc.com/ASSETS/DOCUMENTS/ITEMS/EN/Decora_6375_Catalog.pdf
7/5/2021 2:59:40 PM •
Leviton...
Answered
on Jul 05, 2021
Wiring a leviton 5641 so fan & light turn on separate with red & black wires
the 5641 is a dual switch for three way and single pole. If you want the switches to operate the CF. Connect the power to one of the two screws on the right side as you face the switch. then connect one wire to the screw on the bottom left side. connect the other screw to one of the two screws on the top left. This assumes the Red and Black you mentioned are the switch legs going to the CF.
5/1/2017 3:42:09 AM •
Leviton...
Answered
on May 01, 2017
