Need to clean clogged holes. How does the top arm come off
SOURCE: Clogged
Richard, There should be a spin nut just above the spray arm that attaches to the spray arm hose. Unscrew this and it should come off. Catriver...post back.
SOURCE: Maytag MDB9150
You just have to gently pull it doward. It should unplug relatively easily. To reinstall it, just plug it in it's shaft.
Roger
SOURCE: Maytag dishwasher filter keeps clogging
There is a product made to filter the water going into your dishwasher only to soften the water and remove the calcium before it enters your dishwasher. your dishes will be spotless and it will not get clogged again. you can get it at www.dishwasherfilter.com. it goes right under the sink and is very affordable. you will love this product and it will solve your problems.
SOURCE: How to remove lower spray assembly in order to clean water filter
There should be a plastic nut holding the spray arm. Remove the plastic nut and the spray arm should release.
Does this help you?
Vic
SOURCE: Maytag dishwasher with a spray arm that is stopped
We have a dwu7400 so i'm not sure it is the same, but above the top arm you should see a serrated ring (looks a bit like a flower petal) and that should spin off and the arm should come with it. There's a snap that holds those pieces together that if you squeeze it with your fingers you can get it out. Just reverse that to put it back together.
