20 Most Recent Jet Tech Systems STEALTH Dishwasher Questions & Answers
6answers
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
6/8/2014 12:35:49 PM • Jet Tech Systems... • Answered on Jun 08, 2014
How do you check to see if the dishwasher has power?
follow cord open acces panel carefully test then go past power supply!
6/25/2009 6:32:02 AM • Jet Tech Systems... • Answered on Jun 25, 2009
HOW DO I REMOVE THE TOP SPINNING ARM OF MY MAYTAG
hello
there ar to screws that run int the bottom of the conter. If you open the daor you can see them if you look up. Next remove the lower kick plate. See if this has a steel braid line of copper to the water valve. If it is copper you need to disconect it. Then You should be able to pullit out as long as the installer left a long enough power cord.
Or
remove the plastic nut on the top of the spray arm and the 3 screws in the big out disc. After the sparay arm is remove you will look down itn the middle of the dishwasher and see 6 mor screws. Remove the cover over the impeller and the the one out of the impeller. Then the is 2 more in the lower cover by the impeller.
if both the solution doesn't work then you need to call the customer support number for further assistance
thanks for your time
3/27/2009 2:46:42 PM • Jet Tech Systems... • Answered on Mar 27, 2009
Is running the dishwasher through
That is fine. The vinegar will not hurt it. You will smell the vinegar though. I do it every other month.
Good Luck and Please rate FixYa!
1/7/2009 2:28:48 AM • Jet Tech Systems... • Answered on Jan 07, 2009
How to remove Sprayer Arms
metal sleeves at the end of the lower spray arm?? dont remove them they only protect from hitting against heate and melting. should be a center thumbscrew in spray arm loosen that nut and should come right out, pokin with wire or toothpik willwill clear joles but you gotta remoe the debris from the arm other wise first run will shoot right back nto holes
2/24/2008 3:44:43 PM • Jet Tech Systems... • Answered on Feb 24, 2008
How do I raise the top drawer?
If it is not in the top spot, pull the drawe out and reinsert on the next slider up.
2/16/2022 7:43:03 PM • Jet Dishwashers • Answered on Feb 16, 2022
Water not going thru jet arm in whirpool gold series dishwasher
Are the water jet ports blocked? Food, etc
5/13/2018 3:13:43 AM • Jet Dishwashers • Answered on May 13, 2018
The dishes in my dishwasher are coming out with a white film on them i use the jet dry
Have you used the dishwasher salt in your machine?
4/17/2018 7:24:31 PM • Jet Dishwashers • Answered on Apr 17, 2018
Jet Tech Systems STEALTH Dishwasher Logo
15 questions posted
Top Jet Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Jet Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Jet Dishwashers
  • Jet Dishwashers
Most Popular Question
maytag jet clean dishwasher model
  • Dishwashers
